Go Back   Contractor Talk - Professional Construction and Remodeling Forum > Trade Talk > Flooring
Old 01-09-2009, 09:19 PM   #1
Trade: Carpentry, Remodel
double checking
I'm going to be installing 6 inch white oak, locally milled. This will be the widest I've ever done. I've done up to 5.25. Now my mind is bringing up questions so I know I need to double check. customer doesn't really want screw and plug, my worry is cupping obviously. I was planning on nailing and stripes of glues spaced with nails, straight to the subfloor. Its a post and beam full basement and no moisture issues.
Is it possible to use paper and still glue? or is there something even easier I can use and skip the whole plan.
I'm having the customer rotate the flooring weekly while it acclimates for the next month.... Currently installing a kitchen, which will be photo worthy and I'll be posting that at the end of the month.
so yes no maybe?
ddb maine is offline   Reply With Quote
Double flue down draft ELM Masonry 17 10-28-2008 06:48 PM
Single pole vs. double pole thermostat dforeid Electrical 2 10-23-2008 09:42 PM
CARPENTRY - threading sash weights in double bay window reedchomsky General Discussion 16 10-12-2008 08:32 AM
Replacing double window w slider 1st time dvlscapes Carpentry 5 09-03-2008 01:26 PM
Where to get a Free Business Checking account? kdub1777 General Discussion 8 07-10-2006 08:38 AM
