Discolored Linoleum
Old 01-25-2007, 02:38 PM   #1
72chevy4x4's Avatar
Discolored Linoleum
Because of a tub leak, the linoleum at a job is discolored-having a blackick haze under the surface. What is the discoloration due to-reaction of the subsurface of the linoleum or b/c of the adhesive? It's not mold growth, is it?
72chevy4x4 is offline
Old 01-26-2007, 10:34 PM   #2
tile mason
MattCoops's Avatar
Re: Discolored Linoleum
sounds like mold
do you have pic?
forget linoleum
use tile
vinyl is for cheapos
don't see why anyone would buy that stuff not to mention install it
the 80s are over
chuck that crud out the window
MattCoops is offline
Old 01-28-2007, 05:28 PM   #3
TOBIASD2's Avatar
Trade: FLOORCOVERING
Is It An Actual Linoleum Or Is It Sheetvinyl, There Is A Difference.
TOBIASD2 is offline
Old 01-28-2007, 05:31 PM   #4
TOBIASD2's Avatar
It Also Sounds Like A Problem With The Adhesive Or Subfloor What Is Under It. Was It Installed By A Qualified Installer.
TOBIASD2 is offline
Old 01-28-2007, 07:37 PM   #5
Rich Turley's Avatar
Trade: Residential Remodel
Without seeing the situation, my guess would be particle board underneath that swelled and discolored. Mold may or may not be an issue at this time. I'd recommend replacement.
Rich
Rich Turley is offline
Old 01-29-2007, 02:26 PM   #6
Flooring Guru
Floorwizard's Avatar
Trade: Sales Manager
Most likely the leak is causing rotting.
underlay and possibly subfloor removal is needed.
go back and reinstall whatever material suits you.
Floorwizard is offline
Old 01-30-2007, 09:41 PM   #7
72chevy4x4's Avatar
Portions of the house were remodeled 15 years ago-this bathroom may have been updated at that time, but I'm not sure. To be honest, I don't know the difference in sheet vinyl and lineoleum-can someone educate me?
The offending leak was stopped. I pushed and poked at the floor and could not 'feel' any give. The discoloration is next to the tub where the leak occured-and apparently it was a single large event versus a long gradual leak. If it were vinyl, would it more prone to discolation from water damage at the subtrate level? When mold gets started, will it continue to grow-is it 'treatable' or the is only solution to rip it out?
Old 01-30-2007, 10:40 PM   #8
Flooring Guru
the difference between Vinyl and Lino was described a bit earlier and really does not matter in this case. But there are differences.
usually if the area where the Vinyl and Tub meet is not caulked correctly, then the water will penetrate and cause rotting.
But you would see the Vinyl curl up at the tub.
So maybe it's coming from underneath because vinyl is waterproof.
linoleum disposal? ruger9 Flooring 8 05-30-2007 05:14 AM
Ripping up Linoleum Floor kpikul Flooring 7 02-04-2007 03:44 PM
hardibacker over linoleum A.W.Davis Flooring 6 10-22-2006 03:19 AM
Tile installation over Linoleum JoeI Flooring 7 04-12-2006 02:10 PM
Removing linoleum flooring aarkvt Flooring 6 05-27-2004 12:34 PM
