Difference Between Self-leveler And Rapid Set Concrete?
Old 04-11-2011, 04:56 PM   #1
Tile Contractor
MichaelEmerson's Avatar
Trade: Tile
I sometimes use self-leveling compound to help flatten floors before tiling. It runs $32 a bag so I use as little as possible. Today I saw a product called rapid set concrete which says on the bag "can be used as underlayment". It sells for $18 a bag. I wonder what the difference is? Anyone have experience with these products?
MichaelEmerson is offline
Old 04-11-2011, 04:58 PM   #2
katoman's Avatar
Trade: carpenter
Rewards Points: 2,000
Re: Difference Between Self-leveler And Rapid Set Concrete?
Rapid set is normally used for sono tubes. I don't think you'll get it out of the pail. Stick with the leveler.
katoman is offline
Old 04-11-2011, 04:59 PM   #3
Dan_Watson's Avatar
Rewards Points: 2,466
I would say its the self-leveling part...
Dan_Watson is offline
Old 04-11-2011, 05:06 PM   #4
Tile Contractor
Trade: Tile
If it was mixed very wet I would think it would act in the same manner as self leveler, no? You think it sets up too fast, even with the additive that slows the setting time?
Old 04-11-2011, 05:26 PM   #5
Dan_Watson's Avatar
What additive to slow it down? Its rapid set for a reason.
Are you referring to the Quikcrete products? If so the rapid set will cure way to fast to use in a large area and it is a product meant to be worked not self leveling.
Self leveling is also self finishing so you aren't supposed to work it.
Old 04-11-2011, 05:26 PM   #6
Dan_Watson's Avatar
Wet concrete = Weak concrete
The Following 2 Users Say Thank You to Dan_Watson For This Useful Post:
mudpad (04-11-2011), sbcontracting (04-20-2011)
Old 04-11-2011, 05:29 PM   #7
Project Manager
CookeCarpentry's Avatar
Trade: Project Manager
Rewards Points: 2,016
You think $32 a bag is expensive.
Try Ardex.
CookeCarpentry is offline
The Following 3 Users Say Thank You to CookeCarpentry For This Useful Post:
Dan_Watson (04-11-2011), katoman (04-11-2011), mudpad (04-11-2011)
Old 04-11-2011, 05:33 PM   #8
Dan_Watson's Avatar
And if you really want to get technical those products are not concrete they are cement or better yet grout.
Old 04-11-2011, 05:35 PM   #9
Project Manager
True - if he was actually buying concrete....I doubt it would self-level very well....
Old 04-11-2011, 07:09 PM   #10
ernesto's Avatar
Trade: Licensed Contractor in AZ
Rewards Points: 150
Try Ardex.
Yea, can't wait to try the new K-55. Oh gee, I can't post links yet.
Self leveling self drying, install in 2 hours. Time savings....
Top Floor Installation Co.
Tucson AZ
www.tucsonazflooring.com
http://www.floorsavior.com
ernesto is offline
