05-15-2009, 12:47 PM
#1
Trade:
Aftercare Service
Debonding between the concrete slab and levelling compound
Can anyone help me with the likely cause of the following problem. Debonding has occured between the surface of a concrete slab and the levelling compound used beneath carpet tiles, the compound is still attached to the underside of the carpet tiles but is very crumbly, the entire building (which is a new build primary school) is less than two years old.
Thanks in advance.
Jeff
05-15-2009, 12:56 PM
#2
Handle It!
Trade:
Everything The Union Guys Do Not Want To Do
As with all TASKS in life...............Preparation!
05-15-2009, 01:05 PM
#3
Trade:
Builder/Remodeler
Hard to say, but as Malco said... whomever leveled the slab didn't prep it right.
05-15-2009, 03:06 PM
#4
Trade:
Flooring
I would say patch put over a dusty floor and or not primed first.
Not too much you can do about it now without a rip out
05-15-2009, 03:09 PM
#5
celtic
Trade:
Flooring
Laitence still on the slab?
No preparation to get rid of it prior to laying the latex screed.
You'd be best ripping it all up, priming the floor and possibly use a water based screed over.
05-15-2009, 05:02 PM
#6
Prosource Wholesale AB Ca
Trade:
flooring
screed laid over dusty/porus floor, no primer used, also can not see well from the pic, but if it is a power floated floor they also need primer first,
your best bet is to remove and start again, at least it will all come up easy,
I love jobs like this as i then get paid a very good rate to do it the right way for them.
ian@prosurceab.ca
www.prosourcefloors.ca
11204-178st Edmonton Alberta Canada T5S 1P2
The views expressed are personal and should not be taken as offical ProSource floorcoverings policy
05-15-2009, 05:12 PM
#7
Trade:
Remodeling general
HOpe the OP didn't do it. Sounds like the lawyers are coming
05-15-2009, 05:37 PM
#8
Knowledge Factory
Trade:
Certified Floorcovering Failure Investigator
Looks to me like someone used a portland cement over a gypcrete substrate. Rut-Row!!!
No primer, if over true concrete.
Mixed to watery
No latex in the patching compound.
05-16-2009, 02:35 AM
#9
Trade:
Commerical Construction
the slab could have had curing coating sprayed on to the slab to stop craking as it is curred, the slab could have been green ie more than 5.5% MC when leveling was done.
05-16-2009, 06:36 AM
#10
Trade:
LI,NY designer, new homes, renovation work, concre
Hackery
| Thread Tools |
Search this Thread |
| Display Modes |
Rate This Thread |
Linear Mode
