Trade: Finish Carpenter
Damaged Wood Floors
The appliances were delivered and installed today on a project and the wheels dug in causing indentations in the heart pine floors. I want to try and steam them out a bit before the last coat of poly. It is my first time steaming floors, I have done it on furniture and small projects at home. I am looking for hints and things to avoid
#2 | |
Professional Instigator
Re: Damaged Wood FloorsQuote:
Sam
Trade: Wood Cork and Leather Flooring and more
I love sears guys;they do it all the time and pay me right away!
Being pine there is a chance may be corrected, but I suggest putting a claim to the delivery people(more than you charge your client) and refinish again. |
Flooring Guru
Trade: Sales Manager
Steaming could work depending on how deep it goes.
Used to do it all the time with wood doors. I used a steam iron after soaking an old shirt in water and putting it over the wood and using the iron. Worked damn well.
------------------------ "in 20 years you will regret more what you did not do than what you did" |
#5 | |
Flooring Guru
Retard button. It is new, I made it up myself so I don't offend anyone I use the intials RTBT. I am trying to get Nathan to add this with or in place of the thank you button, can you put a good word in for me?? It has a lot of momentum behind it.
egotistical prick
Trade: Wood Inlay
With pine you might be able to steam it out. depends on the depth and length. It ain't retarded if it works.
Flooring Guru
I agree. Retard button is funny, however it does not apply with this post.
Floors San Francisco
Trade: Flooring
Hi.
I would like to know what is the exact proces of steaming. I undertood this help to fix the minor dents or scraches. I have never used it. I make sure I tell my clients to tell everybody do not scrach the floor. and then I tell the clients again do not creach the floor. Then it is scrached I refinish it again if needed. Thanks |
Steaming is usually a process used to clean or refinish the floors.
Once the woods finish (a scratch) occurs steaming is usually not an option. The water from the steamer may cause damage or introduce unwanted moisture to the wood. This has always been my take on it. I am wrong quite often though |
#11 | |
Trade: Contractor
But I don't believe it will work here. ![]() I do like the retard button idea though. |
Dents and ruts came out and looks great, rtbt to you.
| Wood floors in an elevated bay house (Texas) | Monarchy | Flooring | 22 | 01-30-2010 12:01 PM |
| What type of Non toxic Putty with work on wood floors and accept Tung oil Stain? | refinisher | Flooring | 1 | 01-16-2009 05:29 PM |
| gaps in wood floors. | AbeBarker | Flooring | 8 | 08-25-2008 02:57 PM |
| hydronic heat under wood floors | maderuyck | HVAC | 10 | 09-20-2007 05:46 AM |
| Painting wood floors | steve-in-kville | Painting & Finish Work | 6 | 12-25-2006 09:28 AM |
