Cutting Porcelain Tile
Old 03-23-2008, 08:47 PM   #1
jerome8283's Avatar
Trade: Roofer
What do you recommend I cut my porcelain tiles with? I own a RotoZip and just saw on their site with the appropriate attachment I can use it to make cuts? Has anyone cut tile with a RotoZip? The area I'm tiling is small, only 70sqft. If not the RotoZip can I accomplish cuts without a wet saw?
jerome8283 is offline
Old 03-23-2008, 09:02 PM   #2
Thom
thom's Avatar
Re: Cutting Porcelain Tile
a decent score and snap cutter will work fine. You can use a 4" angle grinder with a diamond blade for compound cuts. Hopefully you can hide the cut edges. A wet saw leaves a nicer edge.
thom is online now
Old 03-23-2008, 09:29 PM   #3
genecarp's Avatar
ditto thom
genecarp is offline
Old 03-23-2008, 09:40 PM   #4
jerome8283's Avatar
Trade: Roofer
What do you guys think of this...Felker FHS-4 Hand Tile Saw
http://www.constructioncomplete.com/...S4HandSaw.html
Old 03-23-2008, 10:46 PM   #5
Its all ball bearings
angus242's Avatar
Trade: Tile
I have one. It works fine but if you're planning on using it as a wet saw, be warned: IT'S MESSY. You would need to cut your tiles outside. I only use it for plunge cuts or any "U" cuts.
Cheaper here:
http://www.felkertilesaws.com/details/1190262108.html
angus242 is online now
Old 03-23-2008, 10:56 PM   #6
jerome8283's Avatar
Trade: Roofer
Cheaper here:
Will it cut 18" tiles?
Old 03-23-2008, 11:16 PM   #7
angus242's Avatar
Trade: Tile
Yes, but I personally wouldn't use it as a replacement for a wet saw. I've never been that great making straight cuts with a circular saw and I'd be worried about it cutting all the way across 18" tiles straight.
Sounds like you're looking for the cheapest way out. Why not just rent an MK from HD? Like $50 per day. With 70 sq ft, you should be done cutting in a few hours.
Old 03-24-2008, 09:45 PM   #8
jerome8283's Avatar
Trade: Roofer
Yes, I will rent. Thx for your help!
Breaking tile edges when cutting Ponsse Ceramic & Stone Tile 12 03-13-2008 01:10 AM
porcelain tile exterior veneer cleveman Masonry 4 12-28-2007 11:36 PM
cutting porcelain tile tomcutt Ceramic & Stone Tile 6 10-31-2007 06:53 PM
Porcelain Floor Tile - fixing sanded grout cracks ETHICS05 Flooring 11 07-18-2007 07:43 AM
Cutting Existing Tile. kpikul Remodeling 16 02-05-2006 12:30 AM
