Cutting Pergo Laminate Flooring
Old 11-15-2006, 03:01 PM   #1
LRG WoodCrafting
Leo G's Avatar
Trade: Woodworker Extraordinaire
Rewards Points: 11,585
I had a contractor friend of mine ask me what blade to use for cutting the laminate floorings. He said he usually uses a standard carbide tipped blade but by the end of the job the blade was shot from cutting the hard laminate. He asked me if a hardi board blade might fair better and I didn't have an answer for him. What type of blades do you guys use to cut the laminate flooring and does it really wear out a carbide blade within a single (250-400 sq ft) job? What blade do you recommend for a good cut and long life? Thanks
Leo
Sawdust Follows Me Everywhere
Carpenter by day.
Mad scientist by night.
http://lrgwood.com
Leo G is offline
Old 11-15-2006, 03:30 PM   #2
Paul
PrecisionFloors's Avatar
Trade: Hard Surface Flooring
Rewards Points: 1,004
Re: Cutting Pergo Laminate Flooring
I use regular carbide tipped 36 tooth 7 1/4 circular saw blades on my table saw and no they do not wear out in one job. On average I get 1500sf worth of floor layed on a blade.
Precision Floors
(772) 237-9900
PrecisionFloors is offline
Old 11-15-2006, 03:38 PM   #3
Teetorbilt's Avatar
Rewards Points: 2,000
Carbide always! I have calculated about 100 sq. ft. more than Precision but use 10" blades on a RAS. I don't buy quality blades for laminate and have a sharpening shop at the end of my street. Lower priced laminates tend to destroy blades more frequently, a distributer once told me that there is more grit in them.
Albert Einstein
Teetorbilt is offline
Old 11-15-2006, 05:11 PM   #4
Tile Contractor
Bud Cline's Avatar
Rewards Points: 518
Seems like they use aluminum oxide for the wear-surface on laminate flooring, I think that's what a rep told me one time. Hell, that's sandpaper!
Anyway when Pergo first hit the streets around here I was doing a lot of Pergo installations and had blade-ware issues so I ran my own little survey. On average I would get 240 square feet of laminate installed before the blade had to go to the shop to be sharpened. I used a 80 tooth carbide. That avaerage held pretty close for a two year period cause that's how long I surveyed it.
FWIW
TO OUR VALUED CUSTOMERS:
Please manage your children.
Any children unattended throughout the day
will be given a Free Mountain Due at our regular quiting time.
Bud Cline is offline
Old 11-15-2006, 05:27 PM   #5
Teetorbilt's Avatar
Bud, was that with carbide blades? What was your cut angle?
I cut it right-side-up with a RAS and tablesaw to prevent chipping and go deep to keep the tooth angle high. With a handheld, you should flip it over and cut from the backside. You have to slow the feed as well, this ain't Balsa that you're cutting. Let the tool do the work.
If you're attacking this like White Pine, you will smoke blades. I learned that on my first floor.
Dad always taught me to "Let the tool do it's work".
Albert Einstein
Old 11-15-2006, 05:43 PM   #6
Tile Contractor
Bud Cline's Avatar
Rewards Points: 518
Carbide blade on a power mitre saw. Didn't use the table saw for anything but rips and never tracked that blade. I think I must have been cutting them sunny-side-up to prevent chipping but don't remember for sure. I haven't done laminate in several years, I gave up on the crap.
Old 11-25-2006, 07:14 AM   #7
J&J Home Imp.'s Avatar
Trade: Flooring and Trim
Rewards Points: 75
I use an 18v cordless skill saw for the end cuts and a table saw for the rest. I also by cheap blades. The 6" blades are a lot cheaper than the 12" for my mitre.
J&J Home Imp. is offline
Old 02-06-2007, 10:41 PM   #8
John712's Avatar
Trade: laminate flooring
You can use saw with motor to cut it. The cutted edge will be very good.
John712 is offline
Old 02-07-2007, 12:57 PM   #9
KoryEmma's Avatar
Trade: Hard wood laminates ceramics vct ect.
I always use a jigsaw because one blade can do the whole job then just trash it put in a new blade and go back to the real froors
KoryEmma is offline
Old 02-15-2007, 10:59 AM   #10
Flooring? What's that?
J DoubleD FLoor's Avatar
Trade: Flooring
Rewards Points: 150
No offense about the jigsaw ... but it would take almost 3 times the time to finish a job just to save a sawblade ... I'm guessing either you have clients that don't care about how long it takes or you only are doing small jobs. I personally use my power miter 12" with a diablo 80 tooth, I have two of them that i specifically use for laminate and have sharpened after every job. They get about 1200 sf each before the smoke comes.
Quality is not expensive ... It's PRICELESS !!!
www.neoflooringco.com
J DoubleD FLoor is offline
Old 02-15-2007, 07:40 PM   #11
Paul
JDoubleD try out a table saw man...you wil find that you can make 90% of your cuts on it, its quicker, dust collection is easier (depending on the saw) and the blades last forever. Seriously, try it and I bet your mitre saw will only cut trim or 3/4 from now on. If my helper uses the mitre to cut laminate he gets his ass chewed off.
Precision Floors
(772) 237-9900
Old 02-16-2007, 12:53 AM   #12
Trade: Flooring
Rewards Points: 150
I use the mitre for crosscuts only ... the rest is done on the table without a fence .... but i'll try the table for the entire job once to see if it speeds things up without tearing up my blades .... btw ... is your helper gaining some weight on his/her rear now?
Old 02-18-2007, 03:50 PM   #13
TURNER FLOORING
turner flooring's Avatar
Trade: Floor installation
Rewards Points: 25
If enough laminate is being installed. I would spend the money on a Laminate cutter that's made like a v.c.t cutter. Around $300 at a flooring supply house.
Only if you are cutting enough laminate in the long haul. To make your money back. Blades are a hassle to run and sharpen; or buy at home depot.
http://TURNERFLOORING2.com
http://www.TURNERFLOORING.com/
Flooring the world over...
turner flooring is offline
Air Bubbles in Laminate Flooring Bigman Flooring 19 09-05-2007 09:07 PM
Question on Laminate Flooring Project53 Flooring 5 04-02-2007 05:52 PM
Laminate Wood Flooring Over An Old Garage Floor mjm0073 Flooring 1 01-30-2007 09:42 PM
What Blade do you use for Laminate Flooring? dayspring Tools & Equipment 8 01-21-2007 01:04 PM
Miter Joints In Laminate Flooring ?? AL MURZYN Flooring 6 12-27-2006 09:15 PM
