Cutting Old Wood Floor
Old 09-27-2006, 08:30 PM   #1
lizzydog's Avatar
Trade: Contractor
What is the best tool to cut old wood flooring even with
baseboard? Not just a few pieces, 14x14 room.
Thanks,
lizzydog
lizzydog is offline
Old 09-27-2006, 09:29 PM   #2
Flooring? What's that?
J DoubleD FLoor's Avatar
Trade: Flooring
Re: Cutting Old Wood Floor
What to you mean .... even with the baseboard? and why are you needing it cut, most of us will need a further explaination
Quality is not expensive ... It's PRICELESS !!!
www.neoflooringco.com
J DoubleD FLoor is offline
Old 09-27-2006, 10:03 PM   #3
lizzydog's Avatar
Trade: Contractor
I want to replace an old hardwood floor. I want to cut along the bottom edge of the baseboard. I do not want to remove the baseboard.
lizzydog is offline
Old 09-28-2006, 12:44 AM   #4
Trade: Flooring
it's going to be just as much work cutting arround it than just removing it ... and you will end up with a better install with removing the base and tearing up the flooring. I really wouldn't suggest leaving the base on unless you just installed over top of the existing flooring ... but i don't even suggest doing that. Do it right and you won't have problems.
Remove base carefully
Tearup old flooring
prep the floor if needed
make any undercuts in doorways if needed
Properly install your new floor
re-install your base
Gl with it.
Old 09-28-2006, 12:53 AM   #5
415moto's Avatar
Trade: General contractor
I second that, although I'd add that if I was replacing the floor, id put in new base as well.
If that aint an option, run a saw around the room at the correct depth, remove the floor in whole strips then tackle the perimeter with a wonder bar/pry bar. 14'x14' aint that big.
415moto is offline
Old 09-28-2006, 03:42 PM   #6
"da Whale don't hesitate"
PrecisionFloors's Avatar
Trade: Hard Surface Flooring
Toe-kick saw is what you'd wanna use...like this:
http://www.craintools.com/fs-specialtysaws.html
Which can be purchased here:
http://www.tools4flooring.com/crain-...saw-p-280.html
It will not get into corners, however, so you will still need a sharp chisel for that. I own one and use it for just the problem you are trying to solve. While everyone would love to just tear out evrything and replace it with new, sometimes the circumstances don't allow for that. What if the base is in great shape already and the H.O. doesn't want to have to pay for something that shouldn't need to be replaced....I can offer the solution, while your not willing to. Just a thought guys
Precision Flooring
(772) 237-9900
PrecisionFloors is offline
Old 09-28-2006, 04:39 PM   #7
Teetorbilt's Avatar
Another reason you might need that saw. On a lot of older homes the flooring was put down prior to installing the walls and sometimes there is nothing underneath it. Many years ago an old geezer told me that plaster ceilings were first put in to catch the dust that sifted through the upstairs floorboards. True? I don't know but it sounds logical.
Albert Einstein
Teetorbilt is offline
Old 09-28-2006, 05:06 PM   #8
Home Improvement Guy
ron schenker's Avatar
Trade: Renovations contractor
an old geezer
Hey Teetor, how old does one have to be to qualify for "old geezer" status
Are you there yet
Don't worry, the baseboard will hide it!
ron schenker is offline
Old 09-28-2006, 06:30 PM   #9
Teetorbilt's Avatar
The guy that told me this was well into his 80's in the late '60's. That would put his BD around 1880-85. This info could have been passed along by his father or grandfather, they were all builders.
Funny sidenote: We called they guy Al Capone because he claimed to drive booze for him in Chicago during Prohibition. One day Dad overheard us laughing about Al's latest story and goofing on him. He stepped up to the plate and informed us that Capone had thousands of drivers and there was no reason that he couldn't have been one of them. Shut us up pretty well.
Albert Einstein
Old 09-28-2006, 06:42 PM   #10
So I guess you'll be an old geezer in less than 10 years
Sorry Teetor, but ever since I turned 50 I've started making fun of people older than me. I guess it makes me feel younger...in a sick demented way
Old 09-28-2006, 07:50 PM   #11
Teetorbilt's Avatar
You will have to change your ways in a while. My grandfather had to start picking on the younger guys again when he was in his late '80's, there were no 'older guys' left!
Albert Einstein
Old 09-28-2006, 08:58 PM   #12
lizzydog's Avatar
Trade: Contractor
Thanks for the information. Teetor this house was built in 1924 and the floor was installed before the walls.
lizzydog
lizzydog is offline
Old 09-28-2006, 09:06 PM   #13
Teetorbilt's Avatar
That stands to reason. So called 'modern' construction didn't start until after WWII.
Do you know if there is a subfloor? There is a good chance that you could pick this one up and be staring at joists. You may want to drill a hole in the corner of a closet to find out.
Albert Einstein
Old 09-28-2006, 09:47 PM   #14
Trade: Flooring
I wasn't suggesting replacing with new base, just remove and re install. Yes some homes had the floors put in first, but 9 times out of 10 they don't have any subflooring. I hope you don't run into any problems and gl with it.
Teetor you are an old Geezer.... hehe I'm young enough to call ya that, you know since I'm one of the young pups here
Old 09-29-2006, 11:30 AM   #15
lizzydog's Avatar
Trade: Contractor
Teetor--It has a subfloor 3/4 or 1" run diagionaly. The problem was caused by improper flashing around a large chimney. Roof was put on 5 years ago. During this time water has been flowing down chimney and wicking through the framing , floor joist and flooring. One reason for not removing baseboard. It is full 8" heart pine nailed to solid 1x4 tounge and grove wall. when drywall was installed it was 1/4 set on top of baseboard. Dont want any drywall repaires.
lizzydog is offline
Old 09-30-2006, 04:31 AM   #16
415moto's Avatar
Ahh some nice stuff to think about putting in the tool box.
My personal preference is all new, I try to avoid piecework. Update it at once so everything can be done efficiently. We almost always do total tearouts, and start new. I can't stand one thing old, but 3 things new like saving old carpet but having brand new everything else. Thats just me though.
Its alot easier to do it at once, rather than to try and go back later and do certain things.
For example a kitchen. Id push for updating the electric and say insulation, plumbing and windows in the wall among others things in a remodel and keep the older dishwasher and fridge if you dont have the budget. Those can be easy replacements later. But going back into the walls or floor after new coverings are in place is much more $$ down the road.
Ive reused base before and to me its not always worth it. Usually its not in great condition to begin with and a similar amount of labor goes back into it. Nailing, caulking, filling, painting. And at the end of the day 30 year old base with 4 layers of paint and worn miter edges doesnt look all that great reused. If it was some classic period trim that was vital to a homes style, then I can see trying to save it if a similar or exact profile couldnt be procured. Or in lizzydog's position trying to avoid damaging the walls and more work. I know we cant always do that, but one can wish.
415moto is offline
Old 10-01-2006, 10:13 PM   #17
dsnAK's Avatar
Thanks,
lizzydog
I'd buy the Fein Multimaster and use an ESAW blade - about the same price as the Crain but does a whole LOT more!!! Yeah I know the 14x14 room would take awhile with the Fein but once your done you have a very versital tool that you'll use every day...
dsnAK is offline
Old 10-02-2006, 07:51 PM   #18
I don't know about you but my time is worth ALOT....the time difference between using a Multmaster and the toe-kick saw would pay me enough to own both .....but then again...I'm a tool whore so I will use any excuse to feed my habit
I will agree that the Fein is a much more versatile tool though
Precision Flooring
(772) 237-9900
Old 10-22-2006, 10:22 PM   #19
lizzydog's Avatar
Trade: Contractor
Old hardwood floor and subfloor is out. Looking at floor joyces. The Craine Toe kick saw worked like a charm. Every thing is flush with base board just like I wanted it. I am going to use 3/4" tounge and groove
plywood for new subfloor. Since this is not going under walls, how much space should I leave for expansion, every thing will be screwed down. Should I fill the expansion space with caulk? New floor will be 1x6
tounge and groove. How much expansion should I leave for it and should I fill it?
lizzydog is offline
2 x 4 wood floor trusses- Help sawit General Discussion 12 07-20-2007 10:55 PM
Laminate Wood Flooring Over An Old Garage Floor mjm0073 Flooring 1 01-30-2007 10:42 PM
sanding a wood floor? daworz Flooring 5 01-26-2007 07:42 AM
2X6 Wood Floor sblade46 Flooring 20 04-02-2006 09:16 AM
Wood cutting blade for 4 1/2" hand held grinder? ryan.s Tools & Equipment 8 02-20-2006 08:29 PM
