Interior Renovations
Cutting 24" Porcelain Tiles
Hey Guys. I am remodeling a kitchen next week and need to lay 24" porcelain tiles on the floor. I have a small wet saw, nothing that can handle tiles this size. I called around to a few tool rental places and they say they have wet saws that would work up to an 18" tile. Can these saws be used to cut a 24"? Im thinking of using a score and snap tile cutter but would prefer a wet saw. Any suggestions on how else I could cut the tiles?
Thanks. |
Chief Toilet Mover
Trade: Bathroom Remodeling
Re: Cutting 24" Porcelain Tiles
Cut part way, turned it around, cut other way. Sucks, but it's been the way of the tile setter with too small of a saw since the cavemen were setting 30" travertine in their caves.
It will get you by if you can't afford or can't find a big enough saw. There is always the old lift up the end of the tile to get that last inch of cut at the end trick works sometimes too. Last edited by Mike Finley; 08-18-2009 at 09:49 AM. |
Pompass Ass
You need a rail saw.
Its all ball bearings
Trade: Tile
Felker TM and larger will cut 24". The Dewalt saw will cut 24" too.
Angus L+M+O+P=C ![]() "Promise only what you can deliver. Then deliver more than you promise" |
Tile Contractor
Four inch grinder with a diamond blade is a helluva lot cheaper if you don't intend to ever do this again.
TO OUR VALUED CUSTOMERS: Please manage your children. Any children unattended throughout the day will be given a Free Mountain Due at our regular quiting time. |
| The Following User Says Thank You to Bud Cline For This Useful Post: | Floordude (08-19-2009) |
Trade: Tile installations
For a one time job, what Bud said.
You can score them 1/3 to 1/2 way through, place a nail under each end on the score line, hold tight down on one side while smacking the other with your palm or a rubber mallet, should snap nice, these will give you somewhat of a rough edge, but hopefully all will be covered by moldings. |
| cutting and installing glass tiles as backsplash | jimmyofc | Masonry | 3 | 06-03-2009 07:46 PM |
| Best sealer for porcelain tiles | qdslse | Ceramic & Stone Tile | 20 | 01-19-2009 10:17 AM |
| Cutting Porcelain Tile | jerome8283 | Flooring | 7 | 03-24-2008 09:45 PM |
| cutting porcelain tile | tomcutt | Ceramic & Stone Tile | 6 | 10-31-2007 06:53 PM |
| Determining Manhours for rolling vs. cutting - your suggestions would be helpful | Zeebo | Painting & Finish Work | 9 | 06-02-2006 06:12 PM |
