Depending on the glaze it may or may not chip, but they are usually small chips and the vent frame should cover it. Take a piece of scrap and try a few cuts first to get the feel. I generally cut from the back side when cutting by hand like that. Seems to get a better cut that way.
I also set the tile on a scrap piece of carpet or foam to help absorb some of the vibration when you cut. Cut slow and easy as floor tile is harder and more brittle, it may crack if you try to force it. If you do that it won't matter where you cut it.
Like reveivl said, it is rather dusty so you might want to cut it outside downwind of the house/cars, etc.
