Cushioning Underlayment For Floating Floor
Old 04-09-2011, 06:33 AM   #1
Frank Jones's Avatar
Trade: Carpentry/Contractor
My Client wants to use her basement for ballet and would like a very cushioned floor. We have strand woven bamboo floating flooring. Is there a thicker underlayment that will give better cushioning? Most of the underlayments I see are only 1/8" thick or less. What about felt?
Basement floor is concrete slab with radiant heating. It is very dry, new construction, great perimeter drain, no wetness even when a hard spring rain melts 30" of snow. I built it myself.
Frank Jones is offline
Old 04-09-2011, 09:55 PM   #2
Orlando Car
Floormasta78's Avatar
Trade: certified floor covering installer.
Rewards Points: 1,154
Re: Cushioning Underlayment For Floating Floor
you can use 1/4 inch cork. not more than that , because its a floating floor and is loose , it can buckle if installed over something thicker . another option but more expensive is rubber underlayment for wood floors. some suppliers carry this and is available in rolls , easier to install and more coverage than cork squares but way more expensive. Quiet Walk is another great and affordable product.
cushioning underlayment for floating floor-mpglobal_quietwalk_1999.gif   cushioning underlayment for floating floor-linoroll_1.jpg   cushioning underlayment for floating floor-main.jpg
Floormasta78 is offline
Old 04-09-2011, 10:00 PM   #3
Fire up the BBQ
griz's Avatar
Rewards Points: 478
Be careful. If your client has seen or is referring to a "sprung floor", they are a system & very expensive. They are very common in pro dance studios. No amount of cushioned underlayment will provide the feel of a sprung floor.
griz is offline
Old 04-10-2011, 01:15 PM   #4
Doer of Many Things!!!
gideond's Avatar
Trade: Paint and Floor Covering Retailer
Rewards Points: 1,135
Kahrs actually makes a gym floor system that would give more the feel the clients seems to be looking for. It's their regular locking hardwood floor with a built in sleeper system attached to it. It's expensive but very easy to do compared to building a traditional sleeper. Since you already have materials that might not be an options anyway.
gideond is offline
Old 04-10-2011, 03:51 PM   #5
astor's Avatar
Trade: FI
Rewards Points: 704
You can use rubber pads(#4) like this under a T&G ply (min 1/2" thick) and float the floor over it. it will raise the floor about 3/4" then otherwise. Mark 1 ft grid on ply (9x5) 45 pieces per sheet and attach with short staples.
The pic below is sport surface system, no need to follow all in your case.
I did couple of Arthur Murray Dance Studios with rubber pads under 2 layers of ply and solid wood over it.
astor is offline
Old 04-11-2011, 06:50 PM   #6
Box Builder
Morning Wood's Avatar
Rewards Points: 8,790
Astor's method looks nice, but the radiant isn't going to be very efficient with that setup. The radiant will lose efficiency with any setup that you're trying to soften the floor up. Keep that in mind
Morning Wood is online now
Old 04-11-2011, 07:23 PM   #7
ernesto's Avatar
Trade: Licensed Contractor in AZ
Rewards Points: 150
I like to use Sound Solution with vapor block, by Healthier Choice Products.
Top Floor Installation Co.
Tucson AZ
www.tucsonazflooring.com
http://www.floorsavior.com
ernesto is offline
Old 04-11-2011, 10:17 PM   #8
astor's Avatar
Trade: FI
Rewards Points: 704
I did not realize it is going over radiant floor!
astor is offline
Old 04-12-2011, 05:55 AM   #9
gideond's Avatar
Yep I missed that too. Unfortunately, you can't have it both ways in this case. If they have radiant heat, they need to forget about adding too much spring to the floor. It isn't worth negating the heat.
gideond is offline
insulating basement floor Bencouver General Discussion 9 01-30-2010 05:41 PM
20k sq ft concrete floor, needs blast, seal, repair, leveling and polyurea BLASTPRO Sandblasting 7 01-16-2010 07:53 PM
sub floor over radiant heat slab benvolio Decks & Fencing 6 12-17-2009 09:39 AM
Floor fill won't adhere to old concrete floor: help?? shaane Flooring 4 12-29-2008 10:21 PM
New Concrete Floor laid, cracking, and sealer Q's. Knyte260 Construction 21 10-06-2007 11:25 PM
