Curved Transition Strip Tile To Hardwood? Is It Possible?
Old 12-25-2011, 06:11 PM   #1
kennysacht's Avatar
Trade: Painter
I'm a paint contractor, but am doing some tiling Honey Do's for my wife over Christmas. I'm tiling a floor that will transition into hardwood. I have a curved (semi-circle like) edge of the tile and need to know if there is any way to transition this to the hardwood floor (to be).
Can this be done or do I need to figure out how to make these straight lines w/o a curve?
Thank you and Merry Christmas!
kennysacht is offline
Old 12-25-2011, 06:21 PM   #2
duburban's Avatar
Trade: building
Rewards Points: 1,294
Re: Curved Transition Strip Tile To Hardwood? Is It Possible?
Yes, you can. Depending on how big of a curve it is, it can be easy or more involved.
is the curve simple or compound and go all over the place.
duburban is offline
Old 12-25-2011, 06:36 PM   #3
kennysacht's Avatar
Trade: Painter
Thank you Duburban. It is a simple curve. So, how do I do this? Can you direct me to any website for further insight?
Old 12-25-2011, 06:52 PM   #4
mikeswoods's Avatar
Trade: interior remodeling
Rewards Points: 2,664
Are you using wood for the transition?
If so, that's a job for a band saw and a router or shaper---
mikeswoods is offline
Old 12-25-2011, 06:57 PM   #5
mikeswoods's Avatar
Schluter makes many flexible metal transitions--however you are stuck with the profiles they make--and the selection seldom works out for me.
Old 12-25-2011, 07:33 PM   #6
duburban's Avatar
Trade: building
if your tight on tooling you can do it with a jigsaw, router, and sander.
i'll give you the rough idea. lay down a big piece of plywood that you can screw an "arm" to. this arm will screw into the plywood on one side and pivot on the screw to match the tile curve. adjust the pivot point until it fits. then transfer this to your wood 3/4 1x8,10,12 whatever fits the curve.
if those don't fit your looking at some gluing up to make the arch it fit.
if no single screw point will make the arm fit come at it from the other side.
start scribing a piece of plywood or scrap material until it fits whatever shape you have.
transfer this line to your new material, and move it back 3/4 or however wide you want the strip to be and strike it again.
meditate for an hour and try to cut the lines perfectly with a jigsaw. err on the side of too much and fine tune with a sander. now come at it with your router and rabbeting bit.
these are the concepts of the job, how you get it done is up to you
duburban is offline
The Following User Says Thank You to duburban For This Useful Post:
TNTSERVICES (12-25-2011)
Old 12-25-2011, 07:34 PM   #7
Hair Splitter
TNTSERVICES's Avatar
Trade: General
Rewards Points: 3,654
My vote would be to make it out of wood. Like Mike said, a router and shaper would do the trick. You could also cut it out of solid stock using a jig saw. Just don't know what your curve looks like.
Tried & True on Facebook
Tried & True Website
TNTSERVICES is offline
Old 12-25-2011, 07:35 PM   #8
duburban's Avatar
Trade: building
This sounds easy! i gotta see what they offer...
duburban is offline
Old 12-26-2011, 11:30 AM   #9
KnottyWoodwork's Avatar
Trade: Trade work for money.
Rewards Points: 512
Cut your header piece into 1/4"ish strips, and clamp/glue them to your from of the curve. I've used homemade-offset cam clamps screwed to the floor, and clamped the pieces straight to the curve. It cut out my time needed to build the form.
Or you could steam bend it, which is my preferred method.
KnottyWoodwork is offline
Old 12-26-2011, 11:35 AM   #10
Carpe Diem
angus242's Avatar
Trade: Smile 4 Tile
Rewards Points: 1,114
Schluter radius transitions if you don't mind metal.
Angus
angus242 is offline
Old 12-26-2011, 03:06 PM   #11
nymasterfloors's Avatar
Trade: Flooring
Rewards Points: 150
Another possibility is a bendable quarter round which i have used many times it is fast and looks good to
Money is evil Family is life Love conquers all
nymasterfloors is offline
Old 12-26-2011, 04:13 PM   #12
astor's Avatar
Trade: FI
Rewards Points: 704
Another option is Johnsonite Contour Edge Transition matching to tile, but I prefer Schluter trims.
astor is offline
Old 12-26-2011, 06:41 PM   #13
Every now and then poster
ohiohomedoctor's Avatar
Rewards Points: 3,544
Just cut every piece exact. Make sure the elevation is perfect also. It will look great!
ohiohomedoctor is offline
Old 12-26-2011, 09:14 PM   #14
cleveman's Avatar
Trade: custom home building
Rewards Points: 2,624
I'm thinking a piece of garden hose with a slit down the middle, nailed down with a roofing nailer.
Swan makes some nice hose. I would go with the nice green color with the yellow stripe.
cleveman is offline
The Following 2 Users Say Thank You to cleveman For This Useful Post:
charimon (12-29-2011), slowsol (12-27-2011)
Old 12-26-2011, 09:17 PM   #15
Tom Struble's Avatar
Trade: siding
Rewards Points: 20
roofin nailer?hack use a trim gun and some power grab
Tom Struble is offline
Old 12-26-2011, 09:28 PM   #16
bluebird5's Avatar
Trade: Licensed G. C. carpenter, flooring, remodeling
Rewards Points: 694
bluebird5 is offline
Old 12-27-2011, 03:59 AM   #17
Orlando Car
Floormasta78's Avatar
Trade: certified floor covering installer.
Rewards Points: 1,154
This is what I use, this reducers are perfect for high traffic areas and are commonly used in Starbucks for transition between laminate and ceramic. I buy mine locally here in san leandro ,california ,. Here's a link to purchase online.
http://www.dssupplies.com/bendable-trims.html
Curved Transition Strip Tile to Hardwood?  Is it Possible?-forumrunner_20111227_015549.png
http://www.facebook.com/#!/certifiedfloorcovering
Certified Floor Covering
Serving All California
( 510 ) 760 - 6810
Floormasta78 is offline
Old 01-05-2012, 10:50 PM   #18
Floors San Francisco
hawaii's Avatar
Trade: Flooring
Rewards Points: 75
Why would you make curved tile? It really does not look good in my opinion.
It is possible to made the make a curved threshold but you have to have tools and skills otherwise you have to hire a pro that will charge you more then you have saved on the entire install.
The easies way, not the pretty, not the best is to cut the tile precisely in curve and then install carpet butt to the tile, good carpet guy will do pretty good job on it. Finding one is not easy and good one will charge extra for it.
Again curves are just expensive so unless you really need it it is best to avoid it.
Da Vinci Floors surfing and sanding.
Honolulu Hardwood Floors San Francisco I Hardwood Floors Hawaii
hawaii is offline
Old 01-05-2012, 10:54 PM   #19
Orlando Car
Hey Hawaii, I'm working in san francisco, on De haro st.. Just letting you know..
( 510 ) 760 - 6810
Old 01-06-2012, 12:10 PM   #20
tom wentzwood's Avatar
Trade: Hardwood flooring
Rewards Points: 25
When doing custome wood floors i like to take templete of area and take it wood working shop for that custome touch ,most home owners love it good luck, wentzwood scottsdale Arizona
tom wentzwood is offline
Tearing Up Tile for My Folks (TILE GUYS PLEASE HELP!)- Opinions Please tuffplay General Discussion 36 03-13-2012 12:11 PM
ADS tile for driveway bridge mcdanie1 Excavation & Site Work 4 06-26-2011 09:26 PM
hardwood around curved stairnosing stack_ca Flooring 16 12-14-2010 08:43 AM
Tub tile backing KennMacMoragh Kitchens & Baths 10 05-12-2010 01:28 PM
Hardwood or tile in Spec House Kitchens williefb Kitchens & Baths 18 02-19-2008 04:37 PM
