Crane Floor Cutter Things
Old 09-25-2009, 05:04 PM   #21
Mike Costello's Avatar
Trade: Flooring
Send a message via Yahoo to Mike Costello
Re: Crane Floor Cutter Things
I own one and use it often .
Go slow, dont force it and keep it flush and it wont kick back on you.
Its like anything else, it takes a few uses to get use to.
I left the shroud on mine and I just tape off the toe kick when its finished wood
Mike Costello is offline
The Following 2 Users Say Thank You to Mike Costello For This Useful Post:
Mike Finley (09-25-2009), the big 12 inch (09-25-2009)
Old 09-26-2009, 02:45 AM   #22
TopFloor's Avatar
Trade: Floorist
I am so flipping nervous when I use this tool. It kicks back everytime. It may be user error. Still, they should design a different handle configuration.
• • • Greatness is a result of focused, deliberate practice • • •
Welcome to our home: www.topflooronline.com
TopFloor is offline
Old 09-26-2009, 10:47 AM   #23
Trailer park boy
shanekw1's Avatar
Originally Posted by CScalf View Post
indeed
Man, you shoulda seen it. Angriest little machine I ever did saw.
Cut the **** outouta 2x4s tho.
shanekw1 is online now
Old 09-26-2009, 10:50 AM   #24
Chief Toilet Mover
Mike Finley's Avatar
Trade: Bathroom Remodeling
Originally Posted by shanekw1 View Post
A buddy of mine stuck a 4" circ. saw blade onto his angle grinder and created a contraption that looked and acted MANY times more dangerous than that little thing.
Craziest cutting I ever did see.
Don't try it.
(unless you're really crazy)
I did that myself just 1 time. Forget the situation, but it was the only solution I could rig up at the time to solve the problem.
I'd heard about other people doing it, so I knew about it already and also knew the notorious stories about it. I held that thing with a death grip the whole time, scared the crap out of me. Wouldn't ever want to do it again.
Mike Finley is offline
Old 09-26-2009, 10:52 AM   #25
Trailer park boy
shanekw1's Avatar
If you let go of it it would probably do laps across the floor, up the wall, across the ceiling and down the wall 5 times before you got it unplugged.
Old 09-26-2009, 10:55 AM   #26
Sean
SLSTech's Avatar
I see one problem right there - starting off nervous tends to make one bunch up, fight the machine, etc... which can lead to the issues you are trying to prevent. Should one have a healthy respect for it or any other tool - yes & quite simply let the machine do the work - don't fight it or try pushing it through at warp speed
SLSTech is offline
Old 09-27-2009, 03:57 PM   #27
finaltouchfloor's Avatar
Trade: Flooring & Remodeling
If your worried about getting hurt by power tools , maybe your in the wrong business OR go oldschool with a hammer & chisel.
finaltouchfloor is offline
Old 09-27-2009, 05:23 PM   #28
Tom Struble's Avatar
Trade: siding
the guys who didnt worry are the ones missing a finger or two
or have scars running across their thighs
Tom Struble is offline
Old 09-27-2009, 05:44 PM   #29
egotistical prick
Cdat's Avatar
Trade: Wood Inlay
I have no scars on my fingers or thighs. My face, however is another story...
Cdat is offline
Old 09-28-2009, 02:16 PM   #30
Tile Contractor
Bud Cline's Avatar
That toe-kick saw right there is by far the most dangerous tool I have ever had in my hands. I don't care how careful you think you are being that little bastard will try to reconfigure your body parts at every opportunity. Mine now stays home in my garage so that my guys won't try to use it. I am the only one that I will consider using that sucker and even then only in extreme cases. Those things are made in Islam.
Bud Cline is offline
Old 09-28-2009, 06:35 PM   #31
BCConstruction's Avatar
Trade: Construction
Have you tried a Bosch roto zip with the zip mate. I have used it many a time to trim baseboards flush and cut out old flooring from infront of kicthen and bathroom cabinets. Has many uses other than this and has almost unlimited ajustment angles.
BCConstruction is offline
Old 09-28-2009, 08:52 PM   #32
I drove my foreman to the hospital today because a craftmen box cutter got dropped on his hand while open with a new blade. It stabbed him right in the middle of the top his hand , 6 stitches.
I will never make smartass safety comments again.
Old 09-28-2009, 09:06 PM   #33
oldfrt's Avatar
Everytime I use a saw in this application,I lock my elbow,and stand clear.
First time I tried this,cutting old ply out next to a tub,I jerry-rigged my biscut cutter.
Pulled off the guard,maxed the blade to the outside,plunged it into floor.
Worked good for a couple secs.
Got brave,tried running it along a line.OOPS!!!!
Had to drive myself to the hospital.
My nurse was the owner of roof I was to start the next day.
After 20 stitches in my thigh,she figured I be a couple of days late on her project.
oldfrt is offline
Old 09-28-2009, 09:50 PM   #34
Designing YourImagination
TurnkeyConst's Avatar
Trade: Custom Remodeling
Originally Posted by angus242 View Post
Mike,
While not as heavy duty, I like this for flush cutting:
You are able to angle it a bit better if you really need to get something flush. The problem with the Crane is you cannot get closer than the shroud allows.
I'll admit, the Crane is vastly superior if you need to do a lot of cutting. However, the Bosch is nice, the replacement blades aren't too expensive and you can flip the blade to get into both right and left situations.
Just an alternative idea if you don't need heavy duty.
While not all the way through the thread yet. I will confirm that these little things are tough and alot more maneuverable than alot of the "circular" version flush cutting saws. Works really good up against cabinets...when removing the subfloor out from underneath when replacing water damaged floors.
So for the money id choose this over the Crane.
Your Main Thoughts On A Job Should Be
1.) Pleasing your Customer
2.) Ensuring the Job is Done RIGHT!
TurnkeyConst is offline
Old 09-28-2009, 09:59 PM   #35
Don't try it.
Also saw the guy on Extreme House Makeover take a 4" grinder and add a blade that resembled the cutting action of a chainsaw, removed the guard for more versatility. Needless to say the next hour or so he went through his hand and into surgery. Wasnt a pretty site....but definitely showed the reason that guards are placed on equipment. Sometimes it might be easier to use...but when you forget about the safety being removed you will find yourself in the hospital.
Good Luck
Old 09-28-2009, 10:27 PM   #36
Tile Contractor
Bud Cline's Avatar
OSHA doesn't apply to those guys???
Old 09-29-2009, 01:17 AM   #37
Tiling & Bath Contractor
TileLady's Avatar
Trade: Tiling & Bathroom Remodeling
I have the rotozip with the zip mate. It does have a lot of kick back. So much so that I don't even use it. Secondly the zip mate casing broke on me. What a POS. Instead of using the zip mate, I just use the diamond blade wheel instead and it cuts wood (like door jams, etc.) beautifully. And no kickback!
TileLady is offline
Old 09-29-2009, 07:07 AM   #38
Builder/Remodeler
ChrWright's Avatar
Trade: Builder/Remodeler
Send a message via Skype™ to ChrWright
Originally Posted by TurnkeyConst View Post
...removed the guard...through his hand and into surgery...
Originally Posted by oldfrt View Post
...Pulled off the guard...20 stitches in my thigh....
Those words preface quite a few "guess what happened" stories around here.
Christopher Wright, CR: President @ WrightWorks, LLC/President @ Central Indiana NARI, Named to the 2010 REMODELING Big50
www.WrightWorks.net - Facebook - Twitter - Carmel Remodeling
Indianapolis Kitchen Remodeling Contractor - You Can Get There From Here
ChrWright is offline
Old 09-29-2009, 07:10 AM   #39
egotistical prick
Cdat's Avatar
Trade: Wood Inlay
...no pain....no gain...
Cdat is offline
Old 09-29-2009, 05:23 PM   #40
Trade: Construction
I dont know what blade i have in mine but i have zero kick back. I can do about 400-500LF of baseboard before the blade is done. But boy does it cut fast. The blade looks like a cross between a diamond blade and wood blade.
What do you do different, let's here the little things that you do that set you apart Mike Finley General Discussion 63 06-14-2010 02:43 PM
Boice Crane wood shaper Cdat Tools & Equipment 2 11-04-2008 08:58 AM
Importance of doing things by email and using contracts HellisLikeNewrk General Discussion 9 09-27-2008 06:37 PM
things i miss Higgs General Discussion 1 09-13-2008 02:07 PM
Crane Fishing GregS General Discussion 5 09-02-2008 08:29 PM
