Cracked Lightweight Concrete Floors
Old 06-05-2008, 06:41 PM   #1
mr.lemna's Avatar
Trade: Home & Commercial Remodeling
We just bought a small two-story office building built in the 1970's. Eventually we are going to replace all of the carpet upstairs. I suspected we had some cracking of the lightweight concrete under the existing carpet and pad. After we closed the sale I pulled up the carpet in the hallway and it looks like "flagstone", no pieces more than 18" square. One piece is loose and rocking. (See photo below left) I pulled up some more carpet in a vacant office and the cracking is not as bad, about half the floor but the pieces are larger and none appear loose. (Please see photo below right.)
I sure I'll run into this elsewhere on the second floor and really don't want to break up and repour 5000 sq.ft. of lightweight concrete.
Can we overlay this with something that will stabilize the floor, after securing the loose pieces? We plan to just go back with more carpet and pad. If so what should we use to overlay it and to first secure or fill in the loose pieces.
Thanks in advance for your help.
mr.lemna is offline
Old 06-05-2008, 07:00 PM   #2
Tile Contractor
Bud Cline's Avatar
Re: Cracked Lightweight Concrete Floors
Ya know what I would do with that mess?
I would use a high powered modified thinset mortar to hard-skim the entire floor. The thinset will get into the cracks and lock the fragments in place. Where the thinset shrinks and settles into the cracks, skim it again.
After that, run a floor machine over the surface to smooth it out a little and install the carpet.
Not a permanent fix but should last for a long long time.
Bud Cline is offline
Old 06-05-2008, 07:47 PM   #3
Professional Remodeler
firemike's Avatar
Darn near every building I work in that has LW concrete floors the floor looks like that. I am doing a condo right now that much of the floor looks just like that. Not much you can do. It cracks because of the flexing in the subflooring.
Below is a photo of the floor in the condo I am working on now. When we removed the kitchen cabinets pieces of LW concrete were tipped down and actually resting on the drywall ceiling for the unit below. We took out about a 4 foot square area of plywood, as much of it was delaminating. You can see in the upper left the plywood is completely disintrigated, and you can see the yellow insulation.
Most of the time I find the subflooring is only 1/2" plywood, all that was required back then, which explains why they look like they do today. A few occasions I have taken some self-leveling cement like Custom's LevelQuik and mixed it up a little on the thin side and pushed it around with a flat squeegee in the bad areas, it locked the loose pieces in nicely.
If you are going to carpet it again, I wouldn't worry about most of it, just take care if the smaller pieces that are loose and popping out. If they rock it is usually because a smaller piece has gotten under a bigger piece, causing the rocking, or the plywood has delaminated. You can use a vinyl-modified patching compound to fill in the holes, the rest should be just fine under carpet.
-Mike-
Falcon Contracting
Residential - Commercial
firemike is offline
Old 06-05-2008, 10:12 PM   #4
"da Whale don't hesitate"
PrecisionFloors's Avatar
Trade: Hard Surface Flooring
Is this gypsum or portland based?
Precision Flooring
(772) 237-9900
PrecisionFloors is offline
Old 06-05-2008, 10:50 PM   #5
Knowledge Factory
Floordude's Avatar
Don't use portland based cement!!! It will spall/blow off the gypcrete.
Check out ARDEX GS-4
http://www.AustinFloorguy.com
Floordude is offline
Old 06-05-2008, 11:23 PM   #6
genecarp's Avatar
thats a good idea, although i would stain it.
genecarp is offline
Old 06-06-2008, 03:40 AM   #7
celtic
Taranis's Avatar
Trade: Flooring
Portland cement /water based screed will be ok provided preparation is done properly, in this case by using a neoprene primer with the screed. This should be supplied with the screed. Such as Ardex K15 or similar.
I would also try to get some bonding primer under the original screed which wil do two things;
1 it may bond some of the f***ed screed to the substrate
2 it will help the s/l screed go down into the cracks deeper as water will not be drawn out of the screed you are laying on its way down, allowing it to get as far down as posssible without stiffening. (Too long a sentence?)
Taranis is offline
Old 06-06-2008, 06:57 AM   #8
atlanta
yes.itsconcrete's Avatar
Trade: decorative conc. & conc. repairs
i don't know how to repair it &, if i don't, you can't,,, on what data do you base the conclusion ' its lightweight concrete ??? ' & how's it been cast - stay in place pan forms ???
in theory, there's no difference 'tween theory & practice,,, in practice, there is !
yes.itsconcrete is offline
Old 06-06-2008, 07:02 AM   #9
mdshunk's Avatar
(is a concrete guy really saying this? )
mdshunk is offline
Old 06-06-2008, 07:22 AM   #10
celtic
Taranis's Avatar
Trade: Flooring
Doesn't matter what it is or how it was laid, all he wants to do is stabalise it for carpet. If he were installing any other topcovering the lot would have to be lifted.
Looking at it it may be a granite or a sand/cement screed.
Vaccum the joints but try not to lift any pieces, that will only loosen the rest of it.
Taranis is offline
Old 06-06-2008, 01:03 PM   #11
Demonseed's Avatar
Trade: Commercial Flooring
Knowing you plan on replacing the old carpet and pad with new carpet and pad, the sub floor does not have to be perfect. If there are loose pieces of the subfloor coming up I would secure them or remove them, clean the sub floor as best as you can, Prime the heck out of it and Patch as needed. Maybe not the "correct" approach, all you are trying to do is avoid any telegraphing through the new materials.
Could you visually detect the cracking under the existing carpet or pad, could you feel it?
Demonseed is offline
Old 06-06-2008, 08:05 PM   #12
Motorboatin' son of a ...
BKFranks's Avatar
Use Planipatch http://www.mapei.us/
I'm working on an 800 unit apartment building and that is what they are using to patch the lightweigh concrete floor.
BKFranks is offline
Old 06-06-2008, 08:46 PM   #13
Knowledge Factory
Floordude's Avatar
Portland over a gypsum based substrate = failure down the road.
You can use gypsum patch over portland but not portland over gypsum.
Old 06-06-2008, 10:04 PM   #14
See any connections here? Floordude is trying to help you here
Precision Flooring
(772) 237-9900
Old 06-06-2008, 11:31 PM   #15
Demonseed's Avatar
Seriously, you must be joking precision. He is putting a tack and pad install over the floor, and you guys are telling him, to level the floor like it is VCT. It is not needed. The original floor cracked and failed and the only way he knew it was by ripping it up.
Why not just do it right, tell him to chip out all of the failing concrete and repour everything. Isn't that the CORRECT way to do it? Put a few extra K into un needed floor prep? Why?. So the world knows you do quality work?
This is a weird thread, with too many overblown ego's. None of the solutions anyone offerred are permanent, so you are basically saying pay someone to do something that will never be right, but you are covering it with Carpet and Pad, so ummm...why spend the money on floor prep?
Please explain, I gave my opinion, explain yours?
Old 06-07-2008, 12:19 AM   #16
Somebody piss in your oatmeal toughguy?
I only give advice to do things one way.....the right way. I could care less if the rest of the world knows I do quality work or not, but they now know you don't, or at least its not a priority.
As far as egos go , I'd suggest you settle the f#@* down, okay cupcake. I didn't piss on any advice you gave (oh wait you didnt, you gave an opinion) Sounds to me like your ego came out to prove how unnecessary our's was. I suggest counseling to explore your inferiority complex....life's way to short to have those demons, I hope you get 'em exercised.
Oh yeah....what happens when a power stretcher gets put on that new carpet install and it pulls the tack strip & patch right off of the slab. There's more to a quality install than just telegraphing. Let me know if you need some educational resources.
Precision Flooring
(772) 237-9900
Old 06-07-2008, 08:25 AM   #17
celtic
Taranis's Avatar
Trade: Flooring
I have to say, although Precision the best way is to remove and redo, it is not really necessary here.
I agree with Demonseed, there is no need to go full scale on prep. The client doesn't require it and doesn't want to pay for it. Do what is necessary for the job in hand. Make good the substrate then give it a finish thats suitable for sheet carpet. Gripfill the gripperrods if necessary instead of using nails.
It will last until the next time the flooring needs replaced and maybe until the one after that.
Cement based screed CAN be used on top of and anhydrite/gypsum with the correct primer. A lot of the time we use Ardex or Balls screeds. Full prep details can be seen here;
http://www.f-ball.co.uk/subfloor_preparation.asp
click on calcium sulphate tab.
I'm sure Ardex will have similar information on their website.
BTW Demonseed, not too many egos here, Bud Cline summed it up in a nutshell early doors.
Taranis is offline
Old 06-07-2008, 10:20 AM   #18
Demonseed's Avatar
Precision (sounds like you had a chip on your shoulder), the point is no matter how much he spends on trying to fix the sub floor, it will never be "Right". If a customer called for an estimate to install Carpet and Pad over that floor, would you deem it neccessary to throw in 10k+ in floor prep? For what amounts to about a 600 yard Install? Think about it, what is the concern here? To have a subfloor suitable for a tack and pad install, that is all.
Old 06-07-2008, 11:15 PM   #19
Knowledge Factory
Floordude's Avatar
For carpet in old apartments with that junk, we busted it all out and installed plywood.
Old 06-08-2008, 02:36 AM   #20
mrghm's Avatar
Trade: Commerical Construction
in the end the installer is responsible.
so what the installer does on each job is up to them,
a simple patch job might come back to bit them in the butt a few months down the track.
in all honesty who would want a sub floor like that under there carpet, even if patched up all some one needs to do is drop something heavy and it is going to crumble.
mrghm is offline
structural concrete... mdshunk Masonry 3 03-05-2009 03:42 PM
Tile over lightweight concrete wopachop Ceramic & Stone Tile 8 06-01-2008 10:45 PM
Lightweight concrete question Snood Flooring 7 03-04-2008 10:32 PM
new wooden floors over concrete?? remodeling joe Flooring 7 03-19-2007 12:17 AM
Concrete floors.... matuszak21 Flooring 4 01-26-2007 11:26 PM
