1. How does the durability of cork compare to hardwood?
It is actually very durable if laid right
(the question has to do with comparison. Cork is softer than wood.)
2. Does the cork flooring fade at all or any faster than another flooring?
no it does not
(it does not fade? or does not fade faster? well maybe not faster, but it will fade.)
3. Advantages / Disadvantages basically of cork, especially when compared to hardwood.
red wine stains it for life, high heels or sharp objects are its worse enemy
(Just like Vinyl or hardwood. I did not hear any advantages....Advantage: Warmer and quieter and better for the earth. Disadvantage: softer)
4. Anything special needed or not needed to clean Cork?
most manufactures sell a cleaning product for it (agreed, but remember to use a terry cloth too)
5. Recommendations for anything at all with it?
make sure it is laid right or the ends curl up use the glue spec'd by the company.
(what if they are looking at the floating floor? but I agree to lay whatever you get correctly)
Use a darker shade as a border around the room and it will really make the floor pop.
(sounds good)
