Youngster
Trade: Builder / Consultant / Designer
Control/Movement Joints
Done enough tile (ceramic, marble, and slate) to know my way around with regard to smaller jobs. Things like bathrooms, foyers, mudrooms, kitchens, showers, etc. The largest single area application that I've done was about 16'x24' before transitions to carpet and hardwood.
The current job is quite a bit larger, so I could use some advice. I've attached a scan of the main floor plan. HO wants pretty much the entire main floor (1400s.f.) done in 18"x18" marble. There will be a 6"x18" border around the walls, staircases, cabinets, etc. and then the center areas will be rotated and laid in a diamond pattern. There will be a couple other embellishments, but they're not really important right now. I'm not sure where movement joints will be necessary/advised. I've marked the locations where I think joints would be appropriate, but I'd really appreciate more experienced opinions. Thanks. P.S. Also, the decision to go with marble instead of hardwood came after the framing stage was completed. I told the HO it is a good idea to add an additional layer of ply over the 3/4" T&G OSB before the CBU goes on. Obviously this is going to ruin the rise on the first stair. The basement ceilings are still open, so I could install additional bracing between floor trusses. Currently the floor is comprised of open web trusses, 16" deep and 19.2" oc (resulting in the same spacing as normal joists 16" oc as trusses have much wider top chord). What say you? |
Knowledge Factory
Re: Control/Movement Joints
Marble, and your not that versed on bigger installations....
Tuscon leveling system, or the QEP LASH system!!!!
Trade: Licensed Electrician
I'm an idiot, was confused
#4 | |
Tile Contractor
Re: Control/Movement JointsQuote:
Doer of Many Things!!!
Trade: Paint and Floor Covering Retailer
I'd say you'll need at least one more expansion joint running vertically in the middle of the dinning/greatroom area. It's been a while since I looked at the spec, but I believe it you look at Schluter's website under the Dilex entry (their expansion joints) they recommend they be place a maximum of 30 feet in each direction.
http://www.morrispaint.com |
#6 | |
Youngster
Thanks for the suggestions on the leveling system. |
#7 | |
Youngster
Conversely the Lash system will run about $500 for this job. The budget can absorb that and I won't have to take a profit cut. |
| Azek butt joints holding up? | LeonardDB | Finish Carpentry | 39 | 11-28-2009 08:30 PM |
| Inaccessible wireway, plumbing joints, etc. | Magnettica | Electrical Picture Post | 9 | 09-15-2008 08:29 AM |
| Tiling over Concrete Expansion Joints | Clueless | Ceramic & Stone Tile | 16 | 11-25-2007 11:48 PM |
| Hardwood Floor Pattern and End Joints | 4yanx | Flooring | 25 | 07-29-2007 07:14 AM |
| Expansion joints for underground fed meter cans | mdshunk | NEC Discussion | 12 | 02-02-2007 03:13 PM |
