Congolium Duraceramic
Old 01-24-2007, 07:23 PM   #21
"da Whale don't hesitate"
PrecisionFloors's Avatar
Trade: Hard Surface Flooring
Re: Congolium Duraceramic
So did they do a good job Rob?
Precision Flooring
(772) 237-9900
PrecisionFloors is offline
Old 01-24-2007, 11:02 PM   #22
robertc65's Avatar
Trade: Former Electrician
Yes they did. My wife and I are very satisfied. The installer made it look real easy. It seems that the grout they use is a bit easier to work with than normal grout. It has a very creamy consistancy. Watching him do the kitchen made me feel like I could tackle our basement bathroom, however I'm sure it's harder than it looks.
Thanks
Rob
robertc65 is offline
Old 12-29-2007, 10:38 AM   #23
all home repair
allhomerepair83's Avatar
Trade: all home repair/ handyman
Thay sale an underlayment that rolls out ,do I use plywood on top? thank you James
allhomerepair83 is offline
Old 12-29-2007, 02:00 PM   #24
Certified Remodeler
silvertree's Avatar
Trade: Kitchen bath remodeler
Did a job almost 2 years ago with Dura Ceramic, owner has a Great Dane doggy. According to her it still looks new. Did another kitchen this month(another Great Dane lover) and expect no problems. 3 jobs total, no grout on any install. Everyone loves it so far.
silvertree is offline
Old 01-03-2008, 07:55 PM   #25
ruglayer777's Avatar
Trade: flooring
can duraceramic tiles be laid over hardybacker or does it have to be installed on a wood or concrete subfloor?
any answer will help thanks
bob
ruglayer777 is offline
Old 01-03-2008, 08:31 PM   #26
GoodHouse's Avatar
Trade: Flooring
Dont put Duraceramic over hardibacker, use a 1/4" birch, or similar type underlayment such as what you use for vinyl flooring. NEVER go over existing vinyl. It always leads to problems. Smooth clean, flat concrete is always good too
GoodHouse is offline
Old 01-03-2008, 08:35 PM   #27
GoodHouse's Avatar
Trade: Flooring
Couple more tips:
Duraceramic is a better product than Durastone due to the edges. Durastone will have a tendency to chip/flake at the corners and it not as reaslistic looking as duraceramic.
Also, if you want bigger grout lines use Tavvy spacers as someone suggested. I only use tavvy spacers for all tile work anyway. But I would not use any spacers and but edge to edge. The tiles have beveled edges so just fill the gully with grout and you get a nice clean small grout line. Looks beautiful. The installation will be much faster and look much better.
Old 01-04-2008, 08:24 AM   #28
Mike Costello's Avatar
Trade: Flooring
Send a message via Yahoo to Mike Costello
If an exsisting vinyl is prepped prperly the manufacturor will warantee the floor over it
Mike Costello is offline
Old 01-04-2008, 04:48 PM   #29
I concur. Proper prep is the key words though. I skim with Ardex Featherfinish if I am going over vinyl. I has to be in great shape though or I pull it.
Precision Flooring
(772) 237-9900
Old 01-04-2008, 08:00 PM   #30
GoodHouse's Avatar
Trade: Flooring
Heres the problem...without tearing up the entire floor you truly never know how well bonded the vinyl is in ALL of the areas. So regardless of mftr warranties, if it fails it will ALWAYS be your fault because they will say the vinyl wasnt properly bonded/prepped.
Another problem is when your setting the tiles and you notice a chip or sratch or something and have to lift the tile to put a new one, the vinyl always pulls up with it lifting from its underlayment and the congoleum glue globs off and you have to do annoying stuff to get it back right.
I will never go over vinyl with basically anything, always could be problems.
Old 01-06-2008, 08:11 AM   #31
Trade: Flooring
I would love to live by those rules too but I am a sub the works for retailers.
Be it a cost issue or a height issue, sometimes we just cant do a subfloor.
There are many ways of checking an old vinyl for proper adhesion,loose edges can be cut away and filled ect.
I use Ardex feather finish too and even scratch up the surface with my buffer and rough grit sandpaper or a belt sander. Followed up with a latex floor primer
I will say that its best left up to a pro.
Old 01-06-2008, 05:52 PM   #32
GoodHouse's Avatar
Trade: Flooring
Mike:
I work for some retailers too and you are correct on what you say; if they do the measure and dont price for rip out because they want to sell the job and not raise the price. Your stuck. I had that exact problem 3 months ago with a dura-stone like product made by mannington. On this one i ate the cost, used some multiply and called the store and told them i dont want to do any more jobs over vinyl, its risky. In reality i cant carry my buffer everywhere i go for a just in case scenario. Becuase without it, it seems the ardex/levelor never sticks well to the vinyl.
Old 01-06-2008, 08:22 PM   #33
Trade: Flooring
When I cant grind or sand (some people have a thing about dust...go figure)
I have been using self leveling primer or use plani patch with the additive.
Been working pretty well.
You are right, its so important to have a total bond with the new luxery tiles and planks.
I am so looking foward to next Monday when I get to stick 1800 ft of Metroflor Tiles to a new slab.
Old 01-07-2008, 12:25 AM   #34
Knowledge Factory
Floordude's Avatar
Here is how you handle it...
Remember all the times you told me I had to take the good with the bad... Well, it's your turn. When you professionally demand respect, you will be surprised how much more you are respected.
http://www.AustinFloorguy.com
Floordude is offline
Old 01-08-2008, 06:43 PM   #35
Flooring? What's that?
J DoubleD FLoor's Avatar
Trade: Flooring
Was reading through here and .... not sure where duraceramic got tied in with VCT or Vinyl ..... from my understanding it only installs like VCT if you are not grouting ... Duraceramic is a limestone composite tile Very much like VCT but not Vinyl Composite
Quality is not expensive ... It's PRICELESS !!!
www.neoflooringco.com
J DoubleD FLoor is offline
Old 01-08-2008, 08:19 PM   #36
Trade: Flooring
In a perfect world sure
Duraceramic vs Endura Dave Buskirk Flooring 0 02-03-2007 10:00 PM
