Concrete Sealant - Which?
Old 03-31-2005, 06:08 AM   #1
Ombligo's Avatar
Trade: check writer
I'm putting laminate down on a concrete slab (location: North Central Florida, about 80' above the water table based on my well depth).
There will be a moisture barrier/underlayment in place. I've been getting mixed answers to my inquiry about further rolling on a concrete sealant. If the retailer or installer sells the sealant they say insist it should be while others without a financial interest say it isn't really necessary.
So, should I seal the slab as well? if so - what product is recommended?
TIA,
Ron
Ombligo is offline
Old 03-31-2005, 11:27 AM   #2
Flooring Guru
Floorwizard's Avatar
Trade: Sales Manager
Re: Concrete Sealant - Which?
I have never sealed a slab when installinf lam, so I do not have any recommendations.
But if it helps with the moisture issue, I say "why not?"
Floorwizard is offline
Old 03-31-2005, 02:57 PM   #3
Teetorbilt's Avatar
I always seal the concrete but the water table around here is only a few feet down. I doubt that you will have any problems if it's down there 80 ft.
It's still cheap insurance. I figure about 1 hr. per coat per 1,000 sq. ft. X 2 coats. The stuff dries fast enough thay by the time you get done with the first, coat,you can start on the second.
In your case, I would say that it's up to you.
Teetorbilt is offline
Old 04-01-2005, 02:54 AM   #4
ccoffer's Avatar
The underlayment will negate any vapor transmission issues,provided you install it properly.
ccoffer is offline
Fiber Optics in concrete countertops 6stringmason Concrete & Paving 17 03-16-2011 05:49 PM
Staining concrete ryan.s Masonry 12 03-05-2009 03:54 PM
structural concrete... mdshunk Masonry 3 03-05-2009 03:42 PM
Concrete Sealants...? BoydS Concrete & Paving 11 05-17-2007 04:25 PM
Concrete home denick Concrete & Paving 5 03-06-2007 04:32 PM
