Concrete Repair Before Epoxy Coating
Old 10-18-2017, 08:53 PM   #1
Ohio painter's Avatar
Trade: Painting and wallpaper
Rewards Points: 2,160
My question is in regards to doing prep work before applying epoxy floor coatings. Typically i will grind a concrete floor to remove sealer or and previous coating. I then address crack repair with Polyurea 2 part crack filler.
Regarding fixing the pock marks / divits / spalding that is usually created by salt dripping off cars.
Over the years i have tried various concrete patches that never work and will fail underneath the epoxy coating.
I tried Armorseal Express patch, a two part epoxy / concrete repair but is was too coarse for the small craters, hard to work with quick set up time and frankly overpriced. (i rarely grumble at cost of products - so long as they work). I called my sales rep and told him how disappointed i was with it.
In talking with an old time concrete time he said there is no fixing them unless doing a full depth repair.
How do others address repairing these bad areas in concrete floors before applying epoxy coatings?
Thanks.
Ohio painter is offline
Old 10-21-2017, 02:16 AM   #2
katilicous's Avatar
Trade: Flooring Natural Stone & Concrete
Rewards Points: 8
Re: Concrete Repair Before Epoxy Coating
Are Feather Finish
Sent from my SM-N910T using Tapatalk
katilicous is offline
Old 10-21-2017, 02:17 AM   #3
katilicous's Avatar
Rewards Points: 8
ARDEX, damn autocorrect
The Following 2 Users Say Thank You to katilicous For This Useful Post:
dprimc (12-26-2017), Ohio painter (10-21-2017)
Old 10-23-2017, 08:10 PM   #4
DiaperRiot's Avatar
Trade: Painting, Landscaping, & Fence Installation
Rewards Points: 148
Ardex isn't bad. Usually for divots, we'll just mix up some cab-o-sil with some epoxy for an epoxy paste. And we'll use that as a patch. And that holds up well. Or if you don't have any cab-o-sil, then you could always mix some sand with the epoxy to get a slurry.mortar. If you have a lot of spalding, you should be almost resurfacing that area. And a slurry/mortar would probably work best in that situation.
DiaperRiot is offline
The Following User Says Thank You to DiaperRiot For This Useful Post:
Ohio painter (10-23-2017)
Old 10-23-2017, 09:25 PM   #5
Mike-B's Avatar
Rewards Points: 496
Anyone try elephant armor products? http://www.gstinternational.com/prod...ormance-mortar
I got a set of prints in a couple weeks ago specifying use of their primer, DOT mortar, and sealer to patch up some caissons.
Never heard of the stuff but the website makes it sound like magic.
Mike-B is offline
Old 10-23-2017, 09:36 PM   #6
I appreciate the replies, some things to think about and try out. Thanks.
Old 10-31-2017, 03:36 PM   #7
http://penncoatinc.com/
PennCoat's Avatar
Trade: Painting / Epoxy Flooring / Polished Concrete
Rewards Points: 706
Depends how large the patch is. Urethane cement is usually a great product, as long as you don't put more than a 1/2" down. It heats up so fast that it can shrink and rip your patch.
PennCoat is offline
The Following User Says Thank You to PennCoat For This Useful Post:
Ohio painter (11-12-2017)
Old 11-01-2017, 10:07 AM   #8
LATICRETE's Avatar
Trade: Manufacturer
If the spalls and pop-outs are smaller, SPARTACOTE Fast Fix will work just fine on this.
For larger ones, a trowelable coat of Duracrete would be a good solution.
LATICRETE is offline
The Following User Says Thank You to LATICRETE For This Useful Post:
Old 11-11-2017, 05:38 PM   #9
claycarson's Avatar
Trade: Tile, Marble, Polished Concrete
Rewards Points: 56
Ardex feather finish or Unipatch are good for thin depths. But they don't have much compressive strength. Very smooth.
For high traffic areas, I use Rapidset Cementall, much stronger but not as smooth. Can go several inches deep.
All of these dry super fast. Don't mix up 50 pounds at once!
Sent from my SM-G920T using Tapatalk
claycarson is offline
The Following User Says Thank You to claycarson For This Useful Post:
Old 01-27-2018, 12:10 AM   #10
rblakes1's Avatar
Rewards Points: 1,116
A friend of mine uses cement all and this one from citadel, I think he's got another one in his line up depending on what he needs. The one in the photo is a feather edge product
Sent from my SM-N910V using Tapatalk
rblakes1 is online now
The Following User Says Thank You to rblakes1 For This Useful Post:
Ohio painter (01-27-2018)
Concrete facade repair. tgeb Concrete & Paving 2 06-29-2014 10:50 AM
Seal Coating Asphalt with Concrete Patches? HammerOn Concrete & Paving 2 12-06-2013 06:14 AM
need help on bidding for concrete jobs! Bconcretegirl Marketing & Sales 15 12-04-2013 12:25 PM
Epoxy concrete drumster21 Painting & Finish Work 6 03-04-2013 03:37 PM
Concrete Repair That Works. 4thGeneration Concrete & Paving 3 10-11-2009 06:50 PM
