Clarke EZ8 Sanding Belt Wear
Old 01-16-2018, 08:48 PM   #1
ceramicbrad56's Avatar
Trade: Wood Refinisher
Rewards Points: 22
Hi. I recently purchased a used EZ8 with expandable drum. It seems to have done a reasonable sanding job on a test floor with one issue-edge belt wear. I looked at the user manual but that issue is not addressed. So I came here to ask if there is something I am doing(running too close to the toe kick) or ? could be causing this.
ceramicbrad56 is offline
Old 01-17-2018, 02:43 PM   #2
Rewards Points: 22
Re: Clarke EZ8 Sanding Belt Wear
Ok, I got it figured out. I did the level adjustment by turning the adjustment bolt 1/2 turn CCW which caused the paper to grab a little more on the right side(opposite belt) of the sander and thus pushed the paper a little more to the left, thus centering the paper. Now it does not eat the paper on the right edge.
Old 01-17-2018, 03:13 PM   #3
sparehair's Avatar
Trade: Painting, flooring
Rewards Points: 1,124
3 things
Paper was not properly fitted even on the drum. Unlikely.
Hit a nail or other protrusion. Possible.
Drum has damage or uneven wear that causes the belt to travel across the drum under pressure. Probable on a use machine.
The drum should be even without rounding at the edges. Problem 2 leads to problem three when there is a cut in the paper, the the drum is run anyway by an inexperienced operator rounding the outside edge leading to travel in the paper.
sparehair is offline
Old 01-17-2018, 03:42 PM   #4
Rewards Points: 22
Originally Posted by sparehair View Post
3 things
Spacehair: Thanks for the reply. The drum has some uneven wear on the edges. Besides hitting nails and so on, what are some specific actions newbies do to the edges of the drum to wear faster than the middle?
Old 01-17-2018, 10:36 PM   #5
sparehair's Avatar
You can buy brand new drum for 350$. If your tools are getting used regularly it will pay for itself. Paper will work better and last longer. You'll get a true 6 inch cut vs maybe 4 on and old football shaped drum.
But if you're really serious about floors you'll get a 220v belt sander and powerdrive or a trio.
Old 01-18-2018, 10:29 AM   #6
Rewards Points: 22
Spairhair:
Thanks for reply. Yes, will get a new drum and eventually move up to 220V system if jobs warrant it, but don't look forward to transporting something I will have trouble carrying.
Old 01-20-2018, 10:02 AM   #7
sparehair's Avatar
Spairhair:
You take the 220s apart. The motor is 80lbs and the chassis 120.
The Tool Belt Thread... 2ndGen Tools & Equipment 1676 02-23-2018 02:19 AM
Sanding... Lugnut1968 Drywall 8 01-18-2015 09:15 PM
Porter Cable Compact Belt Sander Drive Belt Replacement HandyHails Tools & Equipment 2 05-27-2012 12:30 PM
Tool Belt recommendations Please Help ! tnb Tools & Equipment 11 09-25-2008 08:06 PM
12" drum vs 8" belt Poor Floorman Flooring 7 09-09-2008 06:31 PM
