Trade: Drywall & Painting
Chip In Laminate Flooring.
A contractor dropped his drill on a newly installed floating laminate floor and left a 1/4" gouge in it. Does anyone have a professional method for repairing this kind of damage WITHOUT having to tear the boards out?
Re: Chip In Laminate Flooring.
Most flooring guys should be able to replace the panel. It's not a very big deal.
contractor
Trade: carpentry plumbing electric
artist brush and paint.
cm, I'm hoping that it was an attempt at humor.
contractor
nope fellow old guy.just a sugestion that might fix the problem. I did say might.when your only problem is a small flaw get an artist brush.
Re-read, there is a 1/4" gouge! You intend PAINT as a fix?
contractor
Reread--- does it say how long it is.Reread--- I said it might fix it. you are teeterbilt-- with all due respect.
A drop would indicate depth to me as opposed to a scrape, replace the panel. Sometimes, you just have to bite the bullet.
contractor
teeterbilt your cool.I only bite the bullet when I have to.
contractor
I have to bite the bullet often,more so in my younger life. but I still have to often bite the bullet. Learning keeps us young, does it not?
Remodeler Extraordinare
Just replace the laminate tile! Thats an easy fix......next time lay down 1/8" masonite on finished flooring so that doesnt happen again.
Trade: remodeling/specializing in kitchen & baths
kampel seamfill as a second choice
"da Whale don't hesitate"
Trade: Hard Surface Flooring
There are meltable filler kits out there that will fill in/cover up a gouge....if you want to "fix" it a plank replacement is the best way. Find a floor guy who specializes in laminates/hardwood, figure on $150 and about an hour of time.
Precision Flooring (772) 237-9900 Tile, Hardwood, Laminate, and Resilient Installation, Sales & Repair - "We do it right the FIRST time" |
Flooring Guru
Trade: Sales Manager
Precision floors said it best.
------------------------ "in 20 years you will regret more what you did not do than what you did" |
| Air Bubbles in Laminate Flooring | Bigman | Flooring | 19 | 09-05-2007 10:07 PM |
| Question on Laminate Flooring | Project53 | Flooring | 5 | 04-02-2007 06:52 PM |
| Laminate Wood Flooring Over An Old Garage Floor | mjm0073 | Flooring | 1 | 01-30-2007 10:42 PM |
| What Blade do you use for Laminate Flooring? | dayspring | Tools & Equipment | 8 | 01-21-2007 02:04 PM |
| Miter Joints In Laminate Flooring ?? | AL MURZYN | Flooring | 6 | 12-27-2006 10:15 PM |
