Go Back   Contractor Talk - Professional Construction and Remodeling Forum > Trade Talk > Flooring
Closed Thread
Old 01-10-2009, 09:29 PM   #1
Trade: trim subcontractor
ceramil tile over vinyl
I got a job to lay some tile, right now the homeowner has vinyl down. Can i go right on top of the vinyl or do i have to remove the vinyl and lueon. If so durock or cement board instead on lueon. I just want it done right? Please give advice and pros and cons.
Thanks
God bless
s.smith is offline
Old 01-10-2009, 10:49 PM   #2
Tiling Contractor
TileLady's Avatar
Trade: Tiling
The luan and vinyl tile HAS to come up. Secondly, there will be adhesive left from the vinyl and that has to be removed also.
Is tiling your main job? No offense but these questions are quite basic.
TileLady is offline
Old 01-11-2009, 12:03 PM   #3
Tile Contractor
s.smith,
You inquiry should be taken to a DIY Forum somewhere, you are not a member of the tile trades. This forum is reserved for professionals in the trades. Thank You.
Here try this one:
http://www.diychatroom.com/
Bud Cline is offline
Old 01-11-2009, 01:06 PM   #4
Thanks guys. I'm actually a trim carpenter so tile is not my trade but have done it a few times, and understand the question is pretty obvious but always better safe than sorry. I appreciate the help.
God bless
s.smith is offline
Old 01-11-2009, 02:18 PM   #5
Trade: residential remodeling
i take it that the house has a wood subfloor...2nd story or off the ground. will it be too high if you just lay 1/4 inch hardie over the existing floor in comparison to the hall??
remodeling joe is offline
Old 01-11-2009, 08:44 PM   #6
reveivl's Avatar
Trade: Renovations
That'll last at least until the check clears...
"Too much is always better than not enough"--J.R. "Bob" Dobbs
reveivl is offline
Old 01-12-2009, 08:17 PM   #7
Tiling Contractor
TileLady's Avatar
Trade: Tiling
Are you suggesting to lay hardie over the vinyl? If that's what you're suggesting, please refrain from giving incorrect information.
Vinyl has to come up. Period. Check the TCNA handbook (hope you know what that is).
TileLady is offline
Old 01-13-2009, 09:42 PM   #8
if the vinyl sheeting is loose in some spots then yes remove it. some people say remove all subfloors until you get to the original 5/8 plywood sub. i agree but, if the current vinyl floor is rock solid everywhere, then i don't see the problem screwing the hardie thru the subfloor into the joists. no man or "woman" work the same. i've had nothing but good feedback on my jobs and NEVER had a call back. as far as the "tcna handbook" is concerned, "they" always come up with these new ways of doing things "right". one year they say this, then next year they say that. no offense to anyone in their manners of doing it their way. this is only my way and i've been very successful.
Old 01-13-2009, 10:20 PM   #9
Tiling Contractor
TileLady's Avatar
Trade: Tiling
Joe,
The problem with vinyl (especially cushioned sheet vinyl or squares) is that it has 'give' -meaning it can flex. And you can't have 'give' when you're laying tile. Vinyl is easy enough to remove and it should always be suggested to a customer to remove it because you don't want problems down the road. Secondly, from a business standpoint, removing the vinyl generates a little more money.
I am just finishing up a large den tiling job. The customer told me under their carpet was just cement. Once I pulled up their carpet, there was vinyl tiles. They all looked very well adhered but I told them it definitely had to come up. Well when I went to remove it, I couldn't believe how easy they came up. Literally, I took my floor scraper and 'swept' up the old vinyl tiles. It took longer to clean up the debris than it did to remove 300 square feet of tiles. It took me like 20 minutes to remove the tiles that LOOKED so well adhered. In reality, they weren't well adhered at all.
So I'm happy for you that you've never had a callback. But I recommend doing yourself a favor and play it safe. Up with the vinyl! You may wish to check out johnbridge.com as it's all about tiling. That's where us 'tiling guros' hang out.
Happy New Year and best of luck
TileLady is offline
Old 01-13-2009, 11:33 PM   #10
improving homes
Trade: Roofing/Remodeling
I'm going to agree with the play it safe crowd. Two months ago i went to look at a job that failed do to being installed over vinyl and press board. The previous installer put down 1/4" cement board over the vinyl and then tiled. It was only about 3 years old and they ended up having to replace all the tile due to this. Maybe some people have luck with going over vinyl but i have seen first hand failures and would never suggest it.
platinumLLC is offline
Old 01-13-2009, 11:42 PM   #11
dear tile lady
YES!!!!! if it's on concrete, YES remove EVERYTHING!! i was only saying about on wooden subfloors. i would NEVER lay tile on vinyl over concrete. i agree with the "correct" way of wooden subfloor procedure BUT "MOST" people would not Pay for the extra labor involved. . I AM NOT SAYING YOU ARE INCORRECT.
Old 01-13-2009, 11:45 PM   #12
GOOD LORD!!!! if any pressboard is within sight "remove everything"!!!! and start from scratch!! no room for discusion there.
Old 01-14-2009, 06:25 AM   #13
Trade: Flooring
Send a message via Yahoo to Mike Costello
Unless you have x ray vision you should rip out everything. An interflex vinyl is only adhered around the edges but gives the appearance of being down tight.
There are way to many variables involved to give a blanket "as long as its over wood" aproach.
Mike Costello is offline
Old 01-14-2009, 12:19 PM   #14
Flooring Guru
Floorwizard's Avatar
Trade: Sales Manager
Thanks for posting on ContractorTalk.com. The Moderators of this forum would prefer if you post Do It Yourself related topics on our sister site www.DIYChatroom.com
ContractorTalk.com is designed for professional contractor's to discuss issues and topics related to the construction and remodeling industries. Many of our professional contractors are also members at DIYChatroom.com and are looking forward to assist you with your needs.
Please take a moment to post your question at www.DIYChatroom.com If your not already a member of DIYChatroom.com you can sign up for a free account by going to http://www.DIYChatroom.com/register.php/
We apologize for any inconvenience that this may have caused. This thread has been closed.
Floorwizard is offline
Closed Thread
Vinyl Tile Install rate J.A.N.STUDIOS General Discussion 20 11-11-2008 11:44 PM
information on fixing a bad tile job bford General Discussion 4 09-30-2008 06:44 AM
Newer Stick Vinyl Tile cinder11 Flooring 12 05-13-2008 05:12 AM
Vinyl over ceramic tile? tersh Flooring 15 02-17-2008 05:24 PM
Rip up vinyl and put Tile down over OSP flooring killzoneq2 Ceramic & Stone Tile 2 05-07-2007 08:11 AM
