Ceramic Tile Over Concrete Floor
Old 03-08-2007, 07:29 AM   #1
Handyman62010's Avatar
Trade: Jack of all trades, Master of some.
I am planning in installing a 12 x 12 ceramic tile over my concrete basement floor. This is an older house, the concrete is very smooth and appears to have been sealed years ago (dark in color, wet looking but no moisture when I did the taped plastic on floor test).
I am hesitant to use an etching acid to roughen it up unless this is the only solution. Is there any other prepping method than the acid etch to get the mortar to stick properly? Has anyone ever tried a thin coat of "drylock" wall paint on the floor? It penetrates the concrete and chemically bonds to it and has silica in it which provides a rough surface.
Any helpful advice would be appreciated.
Thanks in advance.
Handyman62010 is offline
Old 03-08-2007, 09:59 AM   #2
celtic
Taranis's Avatar
Trade: Flooring
Re: Ceramic Tile Over Concrete Floor
Problem with any "primer" like the one you say - it can't penetrate the concrete because the sealcoat will act as a barrier. You have to remove it, either by mechanical means or acid-etching.
Taranis is offline
Old 03-08-2007, 02:13 PM   #3
Can it be sanded off with a coarse abrasive or is the acid etch the only way to go? I tried sanding to see if that would work but it didn't roughen it up, It was still smooth but was lighter in color.
Question: Does the sealer I am removing penetrate or is it just on the surface?
Thanks for the reply.
Old 03-08-2007, 05:28 PM   #4
R&D Tile's Avatar
Trade: Tile installations
Go rent a scarifier.
R&D Tile is offline
Old 03-08-2007, 08:00 PM   #5
Awesome!
Never heard of it but I will check around and see if I can find one to rent. Sounds like the solution I am looking for.
Thanks
Old 03-08-2007, 09:46 PM   #6
"da Whale don't hesitate"
PrecisionFloors's Avatar
Trade: Hard Surface Flooring
You can rent one at HD for about $40 a day.
Precision Flooring
(772) 237-9900
PrecisionFloors is offline
Old 03-08-2007, 11:13 PM   #7
Flooring Guru
Floorwizard's Avatar
Trade: Sales Manager
you will also need an anti fracture membrane or you risk tiles and grout problems.
Red Guard is one used often around here.
Floorwizard is offline
Old 03-09-2007, 06:50 AM   #8
Why would I need a floor membrane over a solid concrete floor?
I thought that was as stable as it could get...
But I am here to learn from you guys so please let me know.
Thanks again
Old 03-09-2007, 10:56 AM   #9
R&D Tile's Avatar
I would go with a sheet membrane, if no cracks in the slab, not needed, but good insurance, do a search, many crack and uncoupling membranes out there, I would install Ditra or Noblecompays membranes, Flexguard is a good peel and stick one that works very well also.
R&D Tile is offline
Old 03-09-2007, 11:47 AM   #10
BrianDL7's Avatar
Trade: Flooring Installer
A company called Tavy makes a product called "Tileskin" which may work. It is a thin membrane (maybe 3 mil thick), one side is adhered to the floor obviously, and the side facing up has a rough layer similar to a rough concrete surface which mortar can adhere to easily. Honestly it would be alot cheaper to buy muriatic acid and etch your floor rather than to use a seperate substrate to cover the concrete. A product called TSP (tri-sodium phosphate) can also remove the concrete sealer, and it isn't as dangerous as using muriatic acid.
One final note - Drylok does not suggest using its product on the floor for any reason. Before you put alot of money into a home improvement job, make sure you are doing it right, so you don't cost yourself twice as much money down the road trying to fix it.
- Brian
BrianDL7 is offline
Old 03-09-2007, 07:14 PM   #11
R&D Tile's Avatar
Do not use any chemical strippers on the floor, think twice about thin skin and etching the floor has nothing to do with crack isolation, anything else?
R&D Tile is offline
Old 03-10-2007, 04:54 PM   #12
Most of the floor is solid and crack free. I have one crack in an area where tile is to go. Do I use a thin membrane just over the crack area like you would tape a drywall joint or do you have to cover the whole floor with the "Thin Skin"?
I am going to rent the scarifier to prep the surface but what to do with the crack area? I hadn't thought of that as a problem.
Thanks again for all your advice!
Old 03-12-2007, 10:57 PM   #13
Flooring Guru
All I know is that for better assurances that the possible movement of the concrete does not affect the tile, you need a membrane.
it's not deflection.
Old 03-15-2007, 07:10 PM   #14
pitterpat's Avatar
Trade: HandyWOMAN
Go check out the forums at www.JohnBRidge.com, post you r questions in the Tile Forum/Advice Board.
Pat Harris
A HandyWOMAN Service, LLC
"Why call a handyman when you can call A HandyWOMAN?
pitterpat is offline
Old 03-15-2007, 09:40 PM   #15
Great advice there...best tile info site on the internet by far.
Precision Flooring
(772) 237-9900
Learning to install Floor and Wall Tile!! TurnkeyConst Flooring 25 01-17-2008 08:01 PM
Glue on the ceramic tile floor Work is good Flooring 3 07-31-2007 11:40 PM
Ceramic Floor tile grouting John Walls Flooring 9 05-18-2007 07:42 AM
Sealing ceramic floor tile grout? kcrossley Ceramic & Stone Tile 6 04-16-2007 06:17 PM
Cheap Lowes Ceramic Floor Tile n74tg General Discussion 32 06-10-2006 12:03 PM
