#21 |
Tile Contractor
Re: Ceramic Tile Floating Floor
SNAPSTONE Porcelain floating floor tile is still going strong. No problems no errors no complaints. Flooring rehabilitations in the Midwest are up about 14% over the same period last year. Seems the government hasn't found a way to screw up floor coverings just yet.
![]() SNAPSTONE is alive and well.
#22 |
ian @antex western
Trade: flooring
maybe it's just me, but know one appears to have given much thought to how the finished wood top floor will react when it is covered over and becomes a second sub floor with a sealed surface above & below it.
However when in years to come the new top surface is removed and the wood exposed and the rental given back. i bet the landlord will be so glad the new tenants can limbo under the large gap left under the door.
#23 | |
Tile Contractor
Re: Ceramic Tile Floating FloorQuote:
#24 |
Trade: flooring
Bill you are so right...I feel pretty foolish for not noticing the date on that post...yeah I've done my share of different construction but you'll probably find me on here asking for advice more than giving...I am just a girl after all.
#25 | |
tile contractor
I'm not buyin'-- not for that reason, anyway. Welcome to the forum, though!
"Whether you think you can, or you think you can't, you're probably right." http://www.creativeceramicandmarble.com |
#26 |
Trade: Flooring Installer
I was asked to do the same but with porc. I asked someone I knew in the trade of a long time and he said the only way is to make sure whatever flooring it is going over is solid, then he said lay 30# felt down for the tile to adhere to, using vinyl glue and a small V-Notched trowel back butter your tiles and install with spacers of choice size, Then for your grout lines fill with a latex caulk. Easy to maintain, easy to clean, easy to remove. Good luck with your rental project.
#27 |
Tile Contractor
Re: Ceramic Tile Floating Floor![]() ![]()
#28 | |
tile contractor
#29 |
Tile Contractor
Don't hold back Bill, say what's on your mind.
#30 |
tile contractor
C'mon, Bud-- have you ever known me to be shy?
#31 |
bathroom guru
The scary thing....this guy touts himself as an installer!!
#32 | |
Knowledge Factory
YIKES!!! ![]() Seriously?
#33 |
I do it all the time but I use canned frosting to stick it down and vanilla pudding for grout
#34 | |
Knowledge Factory
We will call you Willy Wonka, from now on!
#35 |
Everlasting Gobbstoppers are for commercial use
#36 |
Trade: farm & ranch construction
SOT guys!
#37 |
Trade: Home Improvement/Remodeling
Duraceramic could be another option.
I spent most of my money on booze and women. The rest I just wasted. www.forwardsolutions.net |
#38 |
Trade: -
Hello,
I agree with you. You have given the nice suggestion !
| The Following User Says Thank You to anthonyedger For This Useful Post: | pamela21915 (07-03-2009) |
#39 |
Trade: Oak Floors
Hi,
The advantages offered by engineered oak flooring are numerous. Firstly, it provides for an extra stability over Solid Oak allows it to be fitted in situations where the latter cannot be used. Also, there can be a drastic reduction of installation costs as engineered oak floors can be installed by people as long as they faithfully follow all the specified rules as needed.
Oak Flooring Wales |
#40 |
Trade: AcademyFloor
Ill say that floating floor method is the easiest, fastest and cost effective way of laying your floor down, without damaging the sub-floor of your installation room. I'm not a hundred percent on what the circumstances are on ceramic tile, for i specialize in Hardwood Flooring more than anything.
| Learning to install Floor and Wall Tile!! | TurnkeyConst | Flooring | 25 | 01-17-2008 08:01 PM |
| Glue on the ceramic tile floor | Work is good | Flooring | 3 | 07-31-2007 11:40 PM |
| Ceramic Floor tile grouting | John Walls | Flooring | 9 | 05-18-2007 07:42 AM |
| Sealing ceramic floor tile grout? | kcrossley | Ceramic & Stone Tile | 6 | 04-16-2007 06:17 PM |
| Ceramic tile over concrete floor | Handyman62010 | Flooring | 14 | 03-15-2007 09:40 PM |
