Ceramic Tile On Bouncy Subfloor
Any help from tile experts will be appreciated:
Planning for ceramic tile in the kitchen. Pulled up vinyl and lauan to find another layer of vinyl, then 5/8" ply, then 3/4" osb. OSB is too flexible between joists for my comfort. Planning on 1/2" cement backer board. Will that be enough to handle the flex? Was it a mistake to pull the 5/8" ply? Also, I have found Durrock to be tougher than Hardibacker because of the mesh. Do you think it's the better product, especially since I"m concerned about flex? Thanks. |
#2 | |
Re: Ceramic Tile On Bouncy SubfloorQuote:
anything to strength. Make sure the OSB is oriented on the strength axis, then re-lay 5/8", also perpendicular to the joist. If the subfloor is springy, run a row of screws between the joist.
Lack Of All Trades
Trade: Professional handyman services
There are ALOT of layers to this floor. Maybe spongy area is a repair or moisture infiltration.
![]() I would remove everything down to the 5/8" ply then figure out where problem areas are first. then lay backerboard, etc. Good luck. |
#4 | |
Good guess on the moisture. 24 year old house and only got a vapor barrier 5 years ago. Even with that, the crawl is more moist than I'd like. Welcome to NC. And in my experience osb reacts worse to moisture than ply. |
Custom Stuff
Trade: General Contractor - Custom Renovations
Why not run another 5/8" ply then a layer of Ditra? Should take care of any deflection.
__________________________________________________ ___________ I EXPECT THAT SOMEDAY I WILL SEE THE FRUITS OF MY LABOR. IS IT SOMEDAY YET? ![]() Clifton, Great Falls, McLean, Fairfax Station, Manassas, Virginia Renovation Contractor |
Tiling & Bath Contractor
Trade: Tiling & Bathroom Remodeling
What are the joist specs? 12 or 16 OC, etc
OSB is a big NO NO for tile. If the floor is bouncy, then adding Ditra may not be good enough. You need a solid subfloor. Consider removing the whole subfloor and put down a minimum of 3/4 inch plywood or better. Just my two cents. I don't like Durock or Wonderboard. I don't have faith in anything you can literally break with a good kick. Hardibacker is much stronger. Although as it was already mentioned, cement board doesn't add strength. Last edited by TileLady; 07-10-2009 at 08:14 PM. |
#7 | |
Lack Of All Trades
Trade: framing/remodeling
Guess I gotta go back and repair half of the houses I have worked on in 25 years.
Cmon, this is merely your opinion. While my opinion is that plywood is definitely stronger and holds up better to water, I realize that price can also come into play. If price is no problem, then by all means use plywood. But for the rest of us, osb can and has been used a lot. |
#9 | |
Lack Of All Trades
revised opinion )
| The Following User Says Thank You to Darwin For This Useful Post: | Warren (07-11-2009) |
Custom Stuff
Which is why I suggested running 5/8 ply over the OSB then installing Ditra. Brings the height back up, eliminates almost all of the bounce, and won't be adversely impacted if the OSB were to get wet. Wouldn't hurt to glue and screw the ply. Just MY opinion.
Sean
Darwin - then you have been using the wrong OSB product
Lack Of All Trades
Re: Ceramic Tile On Bouncy Subfloor |
Lack Of All Trades
Trade: flooring
JHM,
What is the floor joist length and depth? If it can't carry the load, your effort is futile. If you have access from below, you can shore up the joists with a beam. olzo |
#15 | |
"da Whale don't hesitate"
Trade: Hard Surface Flooring
Precision Flooring (772) 237-9900 Tile, Hardwood, Laminate, and Resilient Installation, Sales & Repair - "We do it right the FIRST time" |
#16 | |
OSB is perfectly fine for use with Ditra, which is what I'd use, once the deflection is brought up to spec.
Trade: Contractor Residential Construction
[quote=JohnHomeMatters;719717]Any help from tile experts will be appreciated:
Planning for ceramic tile in the kitchen. Pulled up vinyl and lauan to find another layer of vinyl, then 5/8" ply, then 3/4" osb. OSB is too flexible between joists for my comfort. Planning on 1/2" cement backer board. Will that be enough to handle the flex? Was it a mistake to pull the 5/8" ply? Fir plywood TG with PL400, and lots of it. Screws at every 4 inches on the perimeter and 6 inches in the field. I find this process creates a beam out of the floor and relies less on the joists for support. If this does not take out significant deflection then I would go the Shlutter route. Ditra will decouple the tile from the subfloor. |
| Commercial Ceramic tile on concrete slab removal | TD40 | Ceramic & Stone Tile | 4 | 05-27-2009 05:02 PM |
| how many courses for ceramic tile shower walls? | Bazooka Joe | Ceramic & Stone Tile | 19 | 02-14-2009 11:06 PM |
| Ceramic Tile Bumps | Unit 138 | Ceramic & Stone Tile | 7 | 12-28-2008 05:55 PM |
| Removing Porcelain Tile on Stapled and Glued Subfloor | ParaDiddle777 | Flooring | 20 | 11-08-2008 09:48 PM |
| Laying new ceramic tile on wall | faromic80 | Ceramic & Stone Tile | 4 | 09-17-2008 08:01 AM |
