Trade: rehabber
Ceramic Over Luann
Hey folks,
i was wondering if setting ceramic tile over luann would be ok. We had a kitchen floor that was originally supposed to be vinyl squares, laid 1/4 inch luann over 1/2" cdx to patch a few week spots in the floor. After we finished nailing the luann down every 4" with 1 1/2 " ring shank nails, the homeowner and i decided to lay ceramic tile instead of vinyl squares down. i plan on putting 12x12 ceramic tile on the floor. i would rather not add cement board to the floor because of height requirements. |
SAGE
Trade: Remodeler and Finish Carpenter
Re: Ceramic Over Luann
Tough situation. I feel for you.
Tear up the Luan if height is an issue. Do not tile over the luan. Luan is to smooth, it can release oils that will inhibit the bond of the thinset and it has no compression strength. The Luan could compress when you roll something heavy over it like a full fridge and result in popping or cracked tiles over time. Hope this helps. Good luck.
-Lead from the front, or dont lead at all- |
Trade: Tile installations
What's under the CDX?, that should be removed also.
SAGE
Didn't catch that. Good look R&D. 1/2 inch cdx:rolleyes
ContractorTalk Flunkie
Here are a couple of webpages I found, very interesting reading concerning sub-floors and backer-board:
http://www.ctioa.org/reports/fr81.html http://www.ctioa.org/reports/fr46.html Hope it helps.
T.C. "Never met a man yet that I couldn't learn something from"Met a few you couldn't teach though http://remodelingncarolina.com
![]() Last edited by dayspring; 11-30-2006 at 08:50 AM. |
Tile Contractor
The tile industry specifically excludes the use of luan as a substrate for any tile installation.
Luan has a low compressive strength, little tensile strength, and is known to delaminate simply from the moisture in the tile adhesive. Therfore tile cannot be installed directly over luan and it also cannot be in a floor sandwich as a sub-underlayment due to it's minimal laminations .
so can i tile of luan???
just kidding ray |
Trade: Licensed Home Improvement Contractor
You need an inch and a quarter under tile. Like 3/4 subfloor and 1/2 cement board. You dont want the floor to be spongy below your tile.
Flooring Guru
Trade: Sales Manager
too much deflection = cracking.
solid as you can on the substrate. Luan is at the bottom of the list
------------------------ "in 20 years you will regret more what you did not do than what you did" |
Luan has very thin laminates and the bonding glue is not waterproof. The moisture in the thinset could set off a bad chain reaction. (top laminate swelling, loosening)
#11 | |
Tile Contractor
Re: Ceramic Over LuannQuote:
Luan isn't even on the list. In fact, LUAN IS SPECIFICALLY EXCLUDED from all lists with the exception of one, and that is the list of materials that should never be used in a tile substrate.
catalfanoc
![]() Trade: roofing and remodeling
put down a nice wet bed and then just put reducers at the doors
tile mason
luan is for canoes and hockey sticks
not houses
Matt with Cupan Custom Tile & Paint of Lowell, Massachusetts Design and installation of ceramic tile and natural stone for floor, wall, and countertops (978) 601-8774 | cupantile@gmail.com | view tile pictures and more |
Use lots of epoxy with both.
Tile Contractor
The truth is....
Luan is used (after flooring underlayment) primarily for furniture drawer-bottoms and furniture backs. Even as an underlayment under sheet flooring it is still a poor choice. |
Trade: Tile Mechanic
Luan is to tile like Kryptonite is to Superman. NEVER use it. It'll "delaminate" faster than you can say.......well, whatever...
"They Didn't Want it Good...The Wanted it Wednesday..."
Workin' Hard & Havin' Fun
Trade: Deck Designer/Builder
So I think the general consensus is:
Don't keep the Luan. Though what to do to fix it... you're on your own there. (might just have to pull the floor) ~Matt |
#18 | |
Flooring Guru
oops, I meant to say Luan is at the bottom of my drawer
| Ceramic over Ceramic? | Two Brothers | Flooring | 20 | 03-21-2009 09:53 AM |
| Ceramic Floor tile grouting | John Walls | Flooring | 9 | 05-18-2007 07:42 AM |
| Sealing ceramic floor tile grout? | kcrossley | Ceramic & Stone Tile | 6 | 04-16-2007 06:17 PM |
| Are you noticing an increasing of ceramic tiles instead of carpet or other materials? | jurovi | General Discussion | 14 | 02-18-2007 01:38 PM |
| Painting over ceramic tiles?? | theworx | Painting & Finish Work | 4 | 07-07-2006 04:11 PM |
