Ceramic Floor Tile Grouting
Old 04-22-2007, 06:54 AM   #1
John Walls's Avatar
Trade: architect
I notice that the floor tile grouting used by my general contractor seems slightly rough textured and I am afraid ir will gather dirt.
The contractor is about to lay a large area of ceramic floor tiling in my living areas - can someone suggest a smoother textured grout suitable for living areas? In the UK we don't often use ceramic tiles in living area, more accustomed to carpeting. I would appreciate advice in this area.
John Walls is offline
Old 04-22-2007, 09:08 AM   #2
Repair/Remodeling Tech.
jproffer's Avatar
Trade: Repair and Remodeling Services
Re: Ceramic Floor Tile Grouting
What size are the grout lines? Usually floor tile (at least in the U.S.) are layed with 1/4" - 3/8" spaces. Anything over 3/16" gets sanded grout, which looks and feels kind of gritty. I'm assuming this is what you are seeing/feeling. It won't be 100% smooth after it's installed, but I've never had, or heard of anyone else having, problems with it collecting dirt after it's sealed a couple times with a good sealer.
Jim P.
jproffer is online now
Old 04-22-2007, 11:40 AM   #3
tile mason
MattCoops's Avatar
there are unsanded and sanded grouts
generally, only wall tile (and some forms of stone tile) are grouted with unsanded
your floor tile will be fine with sanded grout
wait 3 days after grouting for grout to fully cure
and then seal with a quality sealer
The sealer will help repel dirt and prevent staining
good luck with your project
MattCoops is offline
Old 04-22-2007, 01:06 PM   #4
Rich Turley's Avatar
Trade: Residential Remodel
Another option is epoxy grout, less gritty. Also it won't stain or need to be sealed and re-sealed. Will cost more money though.
Rich
Rich Turley is offline
Old 04-22-2007, 06:26 PM   #5
John Walls's Avatar
Trade: architect
Thank you for those kind replies. The gap will be around 3/16" so maybe yhey will want to put in a sanded grout. The epoxy sound interesting, but it is for 110 sq yds so maybe it would be too expensive. When the grout is sealed, is it just applied to the lines of grout?
Old 04-22-2007, 08:07 PM   #6
Most ceramic tile is glazed and does not need sealing, however, some do. For almost 1000 square feet my charge for epoxy would be around $1500 more than regular grout.
Rich
Old 04-22-2007, 08:22 PM   #7
tile mason
MattCoops's Avatar
square yards???
is the job in Canada?
Old 04-23-2007, 02:34 AM   #8
John Walls's Avatar
Trade: architect
I changed it to square yards because someone mentioned a gap of 3/16" - in the UK we work on metres, but I assumed my responder was working in feet!
Old 04-23-2007, 09:31 AM   #9
Bergess Flooring
JoeBergess's Avatar
Trade: Owner
Talking
I agree with the above replies. It's going to be a textured grout if it's sanded, but make sure you seal it. This will help guard against stains, etc. Aqua Mix makes a product called a "same day grout sealer" that can be applied over the grout after a few hours of it curing. My installers use it all the time, and it works great. It comes in an Aerosol can, so it makes it easier to apply.
Most tile vendors sell it, or something comparable. I'm pretty sure Lowe's carries something like it as well.
Joe
JoeBergess is offline
Old 05-18-2007, 07:42 AM   #10
Doer of Many Things!!!
gideond's Avatar
Trade: Paint and Floor Covering Retailer
If you do go with epoxy, I'd go with Spectralock Pro. It is all "sanded" but of a much finer texture than a normal sanded grout. It is also easier to work with and clean up than a normal epoxy grout, especially the newer "pro" formulation.
gideond is offline
Ceramic over Ceramic? Two Brothers Flooring 20 03-21-2009 09:53 AM
ceramic tile vs quarry tile labor t336 Flooring 2 07-18-2007 08:00 PM
Ceramic tile over concrete floor Handyman62010 Flooring 14 03-15-2007 09:40 PM
Are you noticing an increasing of ceramic tiles instead of carpet or other materials? jurovi General Discussion 14 02-18-2007 01:38 PM
Ceramic over luann scottstef Flooring 17 12-20-2006 12:11 PM
