Trade: Not a Pro contractor - Electronic Background
Carpet Water Damage
If someone had some minor flooding - and I know a lot of people who just did - Is it enough to use a shop vac to remove all possible water, and use a fan ?
All my research states to pull up the carpeting to dry the padding properly (or replace the padding). Eight inches of rain !! |
Re: Carpet Water Damage
(Sorry I meant to post this on the DIY site)
Trade: commercial & residential rental property maintainence
It depends on the quality of the carpet and padding, low quality you might get away with a shop vac, but high quality (it is thicker, retains more water) pull the carpet and padding at least back to allow the air to get under the padding, and also consider the sub floor (wood or concrete). After it is good and dry clean it with a Rug Doctor (much cheaper than a pro, $30 or so including solution and does as good or better job) Remember outdoor flood waters coming inside bring dirt, and everything else from outside. p.s. Buy the carpet cleaning solution from H D or Lowe's, not the rug doctor brand, it works as good or better and is much less expensive.
Trade: hardwood floors
i bet it will always have a bad odor. even if its dry. The pads junk you should get rid of it quick.
#5 | |
Re: Carpet Water DamageQuote:
Good luck, Sellncars Last edited by Sellncars; 07-29-2006 at 08:21 PM. |
Trade: Mold Remediator, Decorative Concrete, Bamboo Fencing,
I have come across some floors that have had minor flooding. Some people pull them and some don't. You may get some mold growing in there. I would say pull it so you have no chance in letting mold grow in your house.
IAQM
www.iaqm.com Elite Concrete Finishing www.eliteconcretefinishing.com Elite Bamboo Products www.elitebambooproducts.com |
IAQM
| Water Damage Repair | AtlanticWBConst | Drywall Picture Post | 7 | 06-15-2010 11:00 PM |
| Hot Water | Joewho | Plumbing | 13 | 11-17-2006 02:39 PM |
| Brick Footer and Water Proofing | emtaboy | Excavation & Site Work | 24 | 07-24-2006 09:48 PM |
| Water Damage | Dusty | Remodeling | 4 | 01-29-2006 10:10 PM |
