Trade: Handy woman
Carpet Underlay
What are the advantages or disadvantages if someone is considering two layers of underpad under the carpet. The underlay is best quality, but homeowner wants extra padding and insullation underfoot.
If this is being done, should foam sides abut with shiny sides bottom and top? Thanks. |
Thom
Re: Carpet Underlay
I saw it done once. It looked terrible.
Some people think they can save money by using more pad under cheap carpet. They need educating. |
Trade: Residential Remodel
Re: Carpet Underlay
Putting two layers of pad under a carpet will lower the life of the carpet and the performance.
Too much cushion will allow the carpet too much flex and bend from traffic. Will be much more likely to develop wrinkles needing to be restretched from time to time and it will wear out quicker. You will be doing the HO a dis-service to use two layers. If the HO wants the best pad stay away from the foam crap. I like slab rubber. Heavier, but it lays and installs great. Rich |
Re: Carpet Underlay
Yep.. pay attentiomn to thom and rich here. Besides looking goofy where it has to dive excessively to tuck under the base board and door casings, the carpet will self destruct pretty rapidly from too much stretching as it is walked on.
Re: Carpet Underlay
My carpet guy won't install cheap pad. He uses the best pad even with the least expensive carpet.
Doer of Many Things!!!
Trade: Paint and Floor Covering Retailer
Re: Carpet Underlay
We won't use cheap pad either. The least we use is 6lb 7/16", no cheaters. There are several places around here selling 4lb cheater as standard though.
Trade: General Contractor & Estimator
Re: Carpet Underlay
I would suggest telling the homeowners if they want a more cushion feel to the carpet to go with a thicker quality pad and/or a thicker longer pile carpet. Better to have a good pad under a cheap carpet than vice versa. I would also tell the homeowners that all pads breaks down in high traffic areas. The better pads just don’t break down as soon. I would not recommend a double layer of pad. The problem is the two layers of pad will move under the carpet and you will end up with ripples where the pad has overlapped and is now three layers thick. You can also get this problem when a single layer of pad is not secured to the foundation so it is allowed to move under the carpet until it wrinkles in some places. This creates waves of hard and soft areas across the face of the carpet that you can see and feel.
#8 | |
Trade: Floor Installer
Re: Carpet UnderlayQuote:
This should never be done. It voids warranties and provides a crap end result. The homeowner should be advised that this is an extremely poor decision. |
| tips on painting baseboards with carpet floor and a tip for new painters | Zeebo | Painting & Finish Work | 10 | 04-22-2011 06:42 PM |
| Baseboard trim before or after carpet | mtheisen0814 | General Discussion | 19 | 05-28-2008 09:58 PM |
| New to carpet tile | J&J Home Imp. | Flooring | 7 | 06-22-2007 07:05 PM |
| Removal of glued down carpet over oak floor | SPEEDSQUARE | Flooring | 6 | 01-07-2007 06:54 PM |
| Carpet and hardwood | J DoubleD FLoor | Flooring | 7 | 09-16-2006 02:03 PM |
