Flooring? What's that?
Trade: Flooring
Carpet And Hardwood
Ok, the young buck needs some help from some of you seasoned pro's.
I have a customer that wants the carpet from a hallway pulled and install 2 1/4" strip bruce ... that's not the problem. He wants that carpet which is nearly new spliced into a bedrooms floor that has a stain in it .... the reminent is big enough to go from wall to wall and wall to about 5' in ... plenty enough to cover the stain but i'm not at all familiar with carpet install ... and also his stairs where done with hardwood and a 2' strip of carpet up the center ... and he wants to keep that look up top and use no transitions ... any suggestions? |
"da Whale don't hesitate"
Trade: Hard Surface Flooring
Re: Carpet And Hardwood
Find yourself a carpet guy to seam on and re-stretch in the room, thats really an easy one. As far as the hall goes...Just to clarify, the HO wants a 2' strip of carpet up the middle of the hall with hardwood down the sides correct? What is the thickness of the material being used? How thick/what type of carpet is being used? It is possible to do sans transitions by having a nice straight, smooth cut where the two will meet. With that done the carpet can simply be tucked to the wood edge.
Precision Flooring (772) 237-9900 Tile, Hardwood, Laminate, and Resilient Installation, Sales & Repair - "We do it right the FIRST time" |
Trade: Flooring
No, the whole hall is getting 3/4" hardwood .... but the stairs come up to the hall and have hardwood steps with a 2' strip of carpet in the center.
I design and manufacture my own transitions to meet the application. Any decent woodworker should be able to fill this bill.
Trade: hardwood floors
talk him out of putting carpet on the steps. very wise
Trade: Flooring
The Carpet on the stairs was existing, but it's ok the job turned out great .... the customer is happy and i've expanded my business to some carpeting and found someone to sub it too.
Trade: Service Contractor
Just curious - How did you wind up fastening the runner down on the stairs ?
Trade: Flooring
The runner was already there and installed at the time of the home's build. The runner on the stairs went into full carpeting on the top of the stairs in the hallway. That is what I pulled up. So on the top step there is a 2' x 1' peice with the newly installed hardwood surrounding it on three sides.
