Can I Use Backer Board For
Old 08-19-2005, 11:16 AM   #1
izote61's Avatar
Trade: house remodeling
i had a shower pan and one of my workers did the mortar bed and it do not looks to good i made have to redo it, or do you know if i can use cement backer board on top of the mortar bed before laying the tile. nothing wrong with the slope, i asking because i saw a tile setter do it that way in one of the do it yourself videos, please advice. thank you
izote61 is offline
Old 08-19-2005, 02:30 PM   #2
Tonkadad's Avatar
Re: Can I Use Backer Board For
If I am understanding you correctly the simple answer is NO! Are you saying that you did a pre slope and than a liner and then a mud bed on top of the liner. You are not going to be able to get the backer board to follow the contours of the slope to the drain and even if you could you won't be able to attach it properly. Backer board is not meant to be used for that purpose.
Don't take this the wrong way but if you can ask that question then the job up to this point probably isn't done properly.
How is the drain connected to the waterproof membrane?
Do a Google search for "John Bridge tile forum" it's a forum devoted to anything to do with tile.
regards,
Bruce Hawkins
Tonkadad is offline
Old 08-19-2005, 05:38 PM   #3
soxfan's Avatar
Trade: flooring
Its $12 worth of sand and Portland cement, if that much. Why take a chance on wrecking the ceiling underneath or even ruining the structure of the floor altogether? Break it out as gently as you can, leak test it by plugging the drain and making sure no water leaves the pan, and then put in a new setting bed. If its just a couple of dips, you can fix that with a little extra thinset.
soxfan is offline
Licensed & Insured bjg5240 Business 34 06-09-2009 07:56 PM
Transitioning drywall with cement board Lone Wrencher Drywall 19 03-02-2008 07:05 AM
thinset under backer board? stringblade Flooring 6 02-12-2006 12:59 PM
Hardi Backer Board...??? dgrabs Flooring 10 05-11-2005 07:04 PM
