Can Deck Glue Instead Of Thin Set For Ceramic Tile? - Flooring - Contractor Talk
Old 11-16-2013, 08:42 AM   #1
rstarre's Avatar
Rewards Points: 93
I have a small 3x4 ft area in front of the entry door that I want to tile. Can I use Loctite Subfloor/Deck 400 to glue the ceramic tiles down instead of thinset
rstarre is offline
Old 11-16-2013, 08:55 AM   #2
Doer of Many Things!!!
gideond's Avatar
Trade: Paint and Floor Covering Retailer
Rewards Points: 1,135
Re: Can Deck Glue Instead Of Thin Set For Ceramic Tile?
Of course you can. Just don't expect good results. I've spent the pas few days scraping up cracked tile someone decided to glue down with construction adhesive.
gideond is offline
The Following 4 Users Say Thank You to gideond For This Useful Post:
CarpenterSFO (11-16-2013), flippinfool (11-27-2013), Floormasta78 (11-17-2013)
Old 11-16-2013, 09:21 AM   #3
GO Remodeling's Avatar
Rewards Points: 96
thinset will support 90+% of the tile versus what? Lines of tube glue? Your "fix" might be quick but when you have to remove it because it cracked, you'll wish you just used the proper cement. Also, thinset would be cheaper than the glue to use.
GO Remodeling is offline
The Following User Says Thank You to GO Remodeling For This Useful Post:
Old 11-16-2013, 09:27 AM   #4
CarpenterSFO's Avatar
Rewards Points: 2,044
Properly applied thinset supplies an even-bearing bed, which helps prevent the tile from cracking. Glue's the hacker's/fly-by-night choice, and might last until the sale closes. If the shoe fits, wear it.
- Bob
CarpenterSFO is offline
The Following User Says Thank You to CarpenterSFO For This Useful Post:
MarkJames (11-17-2013)
Old 11-16-2013, 09:29 AM   #5
The o.p. won't be there to fix it. Not a contractor.
- Bob
Old 11-16-2013, 08:59 PM   #6
ccoffer's Avatar
Rewards Points: 1,140
I don't get the impulse. You can get a bag of Versabond for 12 bucks. Water is pretty much free. Construction adhesive is like 8 bucks a tube for the 30 oz.
What the effing eff?
ccoffer is offline
Old 11-16-2013, 10:29 PM   #7
Paul
PrecisionFloors's Avatar
Trade: Hard Surface Flooring
Rewards Points: 1,004
Further proof that stupid is expensive.
Precision Floors
(772) 237-9900
PrecisionFloors is offline
The Following 4 Users Say Thank You to PrecisionFloors For This Useful Post:
CarpenterSFO (11-17-2013), Floormasta78 (11-19-2013), Gary H (11-19-2013), MTN REMODEL LLC (11-20-2013)
Old 11-16-2013, 11:18 PM   #8
KennMacMoragh's Avatar
Trade: Repair/Remodel
Rewards Points: 3,168
Originally Posted by ccoffer
I don't get the impulse. You can get a bag of Versabond for 12 bucks. Water is pretty much free. Construction adhesive is like 8 bucks a tube for the 30 oz. What the effing eff?
You can walk into Home Depot, grab a couple tubes and they are not as heavy as a bag of thinset. I've used adhesive before on baseboard tile, not because I wanted to, but it actually works on a vertical surface if you have good backing. But yeah don't do it on a floor!
kenparsonscontracting.com
KennMacMoragh is offline
Old 11-17-2013, 04:13 AM   #9
Casey
caseyleen's Avatar
Trade: framer
Rewards Points: 29
Why not just use ceramic tile adhesive instead. Pretty much the same type of adhesive, but in a bucket instead of a tube. When I started in the business back in the 70's, tile adhesive was widely used. But as they became more & more expensive, thin set became the tilers choice because it became much cheaper and it dries much faster. You will get twice the square foot coverage with thin set for the same cost of tile adhesive. In my opinion, adhesive it is better at holding tile to the floor than thin set.
I prefer using adhesive on bathroom floors when possible because it is oil based and has superior water resist qualities. Problem is, you have to wait 36 to 72 hours for it to fully dry.
It sounds like you want to tile the entryway of your house to prevent your hardwood floor or carpet from rain & snow damage dragged in on wet shoes. If you can wait the 36 to 72 hours of not using the entry door, then I would definitely use the adhesive over the thin set.
caseyleen is offline
Old 11-17-2013, 05:50 AM   #10
mikeswoods's Avatar
Trade: interior remodeling
Rewards Points: 2,664
Oh, Please do not use water based adhesive on a floor---
Placed under large tile it will take forever to dry---and the first time the floor gets wet the adhesive will re emulsify--causing the floor to fail.
mikeswoods is offline
Old 11-17-2013, 12:52 PM   #11
rstarre's Avatar
Rewards Points: 93
rstarre is offline
Old 11-17-2013, 02:33 PM   #12
tyb525's Avatar
Trade: Remodeling and Carpentry
It's oil based
I work for a GC, and I do woodworking as a hobby. I also cut most of my own lumber for that with a Woodmizer LT10 sawmill.
Dull tools cause accidents. Sharpen your tools before they get dull!
tyb525 is offline
Old 11-17-2013, 02:46 PM   #13
mikeswoods's Avatar
Originally Posted by tyb525 View Post
It's oil based
AcrylPro is water based acrylic------
The Following 3 Users Say Thank You to mikeswoods For This Useful Post:
charimon (11-17-2013), Floormasta78 (11-19-2013), jamestrd (11-21-2013)
Old 11-17-2013, 02:55 PM   #14
tyb525's Avatar
He mentioned oil based in his post, the picture might be different
tyb525 is offline
Old 11-17-2013, 03:15 PM   #15
ArtisanRemod's Avatar
Rewards Points: 582
Why is this even a question?
ArtisanRemod is offline
The Following User Says Thank You to ArtisanRemod For This Useful Post:
Old 11-17-2013, 04:20 PM   #16
It's easier to do something that you know is hacky if someone else says it's OK.
- Bob
Old 11-17-2013, 05:22 PM   #17
Paul
Please go back to the diy network. This is a professional forum. If you honestly believe in that drivel you need to put the pipe down.
Precision Floors
(772) 237-9900
BCConstruction (11-17-2013), Floormasta78 (11-19-2013), Live_oak (11-17-2013), rusty baker (11-17-2013)
Old 11-17-2013, 06:19 PM   #18
Flooring Installer
rusty baker's Avatar
Trade: flooring
Rewards Points: 48
It also is crap.
Flooring installer since 1973
Armstrong certified
rusty baker is offline
Old 11-17-2013, 06:27 PM   #19
Rewards Points: 582
Hacking strength in numbers?
Old 11-17-2013, 06:27 PM   #20
MarkJames's Avatar
Trade: Handyman Services
Rewards Points: 13,517
You can as long as nobody walks on it.
MarkJames is online now
Leveling wall for tile. DKnafo Tiling 32 06-04-2013 10:56 PM
need help estimating some tile work meselffff Tiling 15 05-08-2013 05:59 PM
Glass tile and thin set color Gus Dering Tiling 17 11-16-2012 09:00 PM
Hidfast Gun redwood Decks & Fencing 28 06-08-2012 06:43 PM
