Brazilian Koa (Tigerwood) Splitting
Old 03-08-2011, 08:15 PM   #1
rdw's Avatar
Trade: Flooring
Does anyone have experience with 3/4 x 5" solid Brazilian Koa (Tigerwood) installation? We are putting this wood in and we are having problems with the tongue splitting. We've tried everything but 18 gauge cleats because we can't find those anywhere.
rdw is offline
Old 03-08-2011, 08:24 PM   #2
rdw's Avatar
Trade: Flooring
Re: Brazilian Koa (Tigerwood) Splitting
We are installing 3/4" x 5" Brazilian Koa hardwood flooring and are having problems with the tongue splitting. I've tried everything but using 18 gauge 2" cleats because I can't find anywhere to buy them. Any suggestions?
rdw is offline
Old 03-08-2011, 08:34 PM   #3
SclafaniBuilder's Avatar
Trade: Builder
Rewards Points: 150
have you tried the bostitch stapler? EHF1838K
SclafaniBuilder is offline
Old 03-08-2011, 08:40 PM   #4
rdw's Avatar
Trade: Flooring
I have a Bostitch stapler that shoots 15-1/2 gauge x 2" staples. Then I switched to a cleat nailer shooting 2" 16 gauge cleats. Can't get either to work. I was able to lower the air pressure on the Bostitch to about 70 pounds with some improvement but still had a lot of splitting. I finished the install upstairs but after the floor sits overnight with no traffic, the next morning the floor crackles when walked on. I think the crackling is caused by the splitting. Any thoughts on glueing?
rdw is offline
Old 03-08-2011, 08:47 PM   #5
slowsol's Avatar
Rewards Points: 2,192
This floor was glued. I did not install, but did some other renovation in the condo. It looked like a troweled on glue and it was popping up in a few spots throughout the place.
-John
slowsol is offline
Old 03-08-2011, 08:51 PM   #6
rdw's Avatar
Trade: Flooring
Thought about combining the glue and the staples. Extra insurance and hopefully might control the crackling.
rdw is offline
Old 03-08-2011, 09:07 PM   #7
Commercial Contractor
Mud Master's Avatar
Trade: Commercial General Contractor
Rewards Points: 1,000
Send a message via AIM to Mud Master
What type of underlayment did you install?
Originally Posted by katoman View Post
And when the day is done, I can look myself in the mirror, with pride, and say " you're a craftsman, well done. "
Mud Master is offline
Old 03-08-2011, 09:42 PM   #8
Paul
PrecisionFloors's Avatar
Trade: Hard Surface Flooring
Rewards Points: 1,004
What gun and fasteners are you using? Operating pressure?
Precision Floors
(772) 237-9900
PrecisionFloors is offline
Old 03-08-2011, 09:45 PM   #9
rdw's Avatar
Trade: Flooring
Used felt paper. The area that I have already completed is upstairs. The subfloor is 1 1/8" Advantec glued and screwed to 16" floor trusses on 16" centers. Kinda overkill but it is solid, about as close to rock solid as wood subfloors get. Once you walk around on the floor for a bit the crackling goes away and doesn't seem to happen again until it sits for a day or so with no traffic on it. Sometimes seem worse than others, I have tried make some connections with temp, humidity, etc but haven't really had a consistent result.
rdw is offline
Old 03-08-2011, 09:47 PM   #10
Carpe Diem
angus242's Avatar
Trade: Smile 4 Tile
Rewards Points: 1,114
Merged 2 threads.
Angus
angus242 is offline
Old 03-08-2011, 09:57 PM   #11
rdw's Avatar
Trade: Flooring
I used a Bostitch stapler with 15 1/2 ga x 2" staples, with a large range of pressures with the best results at about 75psi. I also tried a Freeman cleat nailer with a 2" x 16ga L cleat at anywhere from 85 to 110psi but that seems to split also.
rdw is offline
Old 03-08-2011, 10:02 PM   #12
rdw's Avatar
Trade: Flooring
I have one of those but it doesn't shoot a long enough staple, so no I didn't try it.
rdw is offline
Old 03-09-2011, 05:05 PM   #13
jamestrd's Avatar
Trade: wood flooring
Rewards Points: 1,280
its the wood..too dense..all those brazilian woods do that..
the floor is also plank..it will be "walked out" and the crackling will go away as it acclimates to the space more, in its installed state..
with that subfloor, i doubt u have any worries on your hands..
if there is no climate control right now, the floor will continue to crack and occasionally until that is resolved.
and of course glue will help...but dont think that is your issue..try leaning forward on the nailer...
James Hernandez
All Flortec Inc.
West Milford,NJ
www.flortechardwood.net
jamestrd is offline
Old 03-09-2011, 09:07 PM   #14
rdw's Avatar
Trade: Flooring
Thanks everyone for the input. I do have the heat on and it is holding a steady 69 deg. but I have no way to control the humidity, and being winter the rel. humidity in the house hovers around 40% to 45%. I haven't tried leaning forward on the nailer but I will. Thanks for the tip, I will update on how it's going as soon as I get started back on it. I have been told the only other alternative is to pre-drill and hand nail, I don't even want to think about how lond it would take to do 1500 ft of that!
rdw is offline
Old 03-09-2011, 11:13 PM   #15
astor's Avatar
Trade: FI
Rewards Points: 704
Try taping a shim (thick part in the back) on the shoe plate of the nailer. You may try adding more until get better results. 2" cleats go 33/32" deep without shims, with shims they will go down a little less but it may reduce the splitting.
astor is offline
The Following User Says Thank You to astor For This Useful Post:
Metro M & L (03-10-2011)
Wax for Tigerwood mikec Decks & Fencing 1 10-02-2010 06:39 PM
Questions about brazilian walnut and finish mattsk8 Flooring 7 12-14-2009 10:33 PM
preferred fastener for Tigerwood JohnHomeMatters Decks & Fencing 9 10-20-2009 08:53 PM
new tigerwood deck -- boards with fuzz, green-yellow tint? andywocky Decks & Fencing 32 08-20-2009 04:10 AM
Non-Blast Rock Splitting MetroWest Rock Excavation & Site Work 0 06-06-2009 08:44 PM
