Trade: Home Improvement Contractor
Brazilian Cherry Flooring
I have a client that has Brazilian cherry flooring and it's only a year old and has a very dull finish with gaps everywere. Looks like the installer had one to many on this one.
Is there any way to fix this without replacing the floor? Don't get me wrong this floor has awsum color it's 3/4 x 5" wide plank. Here is a couple of pics on what i am dealing with. The finish is dull and scuffed. Ram |
Re: Brazilian Cherry Flooring
You should be able to hire a flooring contractor who will then give it an exta coat of finish. He will be able to determine what type of finish to use. He can also fill some of the gaps...although the wide plank flooring usually will show moore gapping than the narrow stuff.
By the pictures you have there, the floor doesn't look too far gone. Check at the high traffic areas such as entry, fridge, turning points in hall. If you see grey areas that is where the finish is worn down to the wood. This can be fixed locally also if the right conditions are there.
I admit...I don't know everything...but don't tell my kids I told you.
Trade: hardwood floors
It look as if it was not acclimated corrrectly. Brazilion woods are very unstable and should be acclimated to the relative humidity of the house. Anyway now that it has settled and got happy you need to sand it down and trowel fill it with brazllian cherry filler. If they want it to shine, coat it with semi-gloss for a happy medium shine. It may have lost it shine because of a wax-based cleaner. If a wax-based cleaner has been used you cannot re-coat it. You must sand it down.
C'mon guys, we really need to know where you are with these questions.
If that house has been closed up for the winter with low humidity, the wood will lose moisture and shrink. It's the way wood 'works'. If you fill the gaps in this condition and then open the house for spring, the wood will expand and the floor will bubble or 'pop'. I'd ask a lot of questions and shift to a wait & see attitude.
#5 | |
Re: Brazilian Cherry FlooringQuote:
#6 | |
Thanks for the input. Ram |
#7 | |
Ram |
I'm working on a 1-story new construction house and have a few questions along the same line. Due to past few months of rain, water has collected underneath the house leaving the soil damp for the last few weeks, common yearly occurance for the neighborhood. Before the roofing went in, it rained over the 3/4" OSB subflooring causing it to expaned and curl at the edges. Today the flooring guys came in and sanded the curled edges down and measured the humidy of the OSB which ranged from 12-20%. Approximately 2600 sq. ft. of Brazilian cherry wood, 3/4"x6" wide planks, have been acclimating inside for the last 3-days. The flooring contractor says that the humidy has to be 10% or less and that he can't guarantee the hardwood will not curl or buckle next rain season when the water collects under the house. A drainage system is currently being put in place but will not completely divert all the water. Besides waiting for the OSB to dry out, what are some of the solutions for this type of scenario and what would recommend? I'm officially the painting contractor for the job but I also help out the general contractor with issues and deal with the coordination when he's not around.
I checked with the installer of this floor and the Brazilian was 7% and the trim on the door frame was 7.5% so he said ok to install. He never checked the floor itself for moisture and there was water in the basement. He did put tar paper down first but I am not an installer so I don't know if that's the right way or not. I have yet to refinish so the outcome unknown right now.
Ram |
#10 | |
| Hardwood Flooring - First Go at It | DecksEtc | Flooring | 56 | 10-05-2006 01:41 PM |
| Hardwood Flooring For Large Projects | StonewoodSP | Marketing & Sales | 1 | 12-08-2005 09:38 PM |
| Re-claimed Vertical grain fir Flooring | Coop | Flooring | 5 | 11-13-2005 08:49 PM |
| br111 triangulo brazilian cherry 3/8 | conrad | Flooring | 2 | 08-26-2005 08:26 PM |
