Better Way To Tack
Old 12-10-2005, 06:56 PM   #1
Flooring North Cackalacky
drunkrussian's Avatar
Trade: Hardwood floors, everything about them
Better Way To Tack
Ok,
Today was horrible. Have to coat about 2000sq/ft, 38 stairs and 2 landings, and be done by tomorrow. Buffed it last night, came back today, stated vacing and tacking. Started putting the finish on, and jesus, tons of crap in the finish. I preped extra hard so this would not happen.
I've tacked w/ water, mineral spirits, swiffer pads... does anything work better? I don't know what else to do other than buy a gas powered vac. Anyone have any tips or secrets?
drunkrussian is offline
Old 12-10-2005, 07:46 PM   #2
Teetorbilt's Avatar
Re: Better Way To Tack
Sounds to me like you're getting something from another source. Are the windows open? Did you sand? Did you wipe the walls after sanding? Are there animals involved? Are the HO's living in? You have obviously overlooked something.
Albert Einstein
Teetorbilt is offline
Old 12-10-2005, 08:39 PM   #3
I did the sanding job, then sanding sealer. Buff, then vac. Window are shut, and the ac/heat is not blowing.
I am starting to think it was the walls. I did have some dust collection problems (hole in the drum sander bag) during sanding. Never really thought of that, so i'll give it a shot. Thanks
Old 12-10-2005, 08:53 PM   #4
Teetorbilt's Avatar
Dust does like walls, I don't know why. Static? You also create a breeze just by moving around. Dad taught me about all of this and it is embedded so deeply that I just do it without thinking.
The hole in the sander bag is a big tipoff, you may want to do the ceilings too. Start at the top and work down.
Wish that I had a tip for dealing with the bugs. Anyplace, anytime, any job, at least ONE will get stuck. LOL
Albert Einstein
Old 12-10-2005, 09:03 PM   #5
Chief Toilet Mover
Mike Finley's Avatar
Trade: Bathroom Remodeling
Aw, forget it. I thought this was a thread about sailing.
Mike Finley is offline
Old 12-10-2005, 10:46 PM   #6
Teetorbilt's Avatar
Diaper hoister! Going sailfishing in the AM. Probably grab a few Dolphin too.
Albert Einstein
Old 12-10-2005, 10:59 PM   #7
old27's Avatar
Trade: Work
I'm going x-mas tree shopping tomorrow. I think I'd rather be you a million times over...Tight lines.
-old27
old27 is offline
Old 12-11-2005, 12:34 AM   #8
Teetorbilt's Avatar
I'll post later.
Albert Einstein
Old 12-11-2005, 04:41 PM   #9
adams,b's Avatar
Trade: hardwood floors
make sure the air is off in the house. Make sure its not bubbles in the finish, and make sure your lambswool is not coming apart. YOu can also strain your finish with an old screen. I always wipe the steps down with a rag damp with some thinner.
adams,b is offline
Old 12-12-2005, 12:05 AM   #10
Marco's Avatar
Trade: Hardwood Flooring
Location: The Oak Floors of Marco Los Gatos, CA 408-353-4882
I'm wondering what kind of finish too. No mineral spirits under water....I never had any problem with dust on walls as long as I didn't touch them and all the air movement is stopped. Strain the finish. i vaguely remember hearing about someting similar happening with oil base. Some other forum tho...
Marco is offline
Am I outrageous? AAPaint Painting & Finish Work 39 02-16-2007 12:58 AM
tack cloths rservices Flooring 12 12-13-2006 07:29 PM
Have you run into this before? ron schenker Flooring 7 02-09-2006 11:46 AM
How much to charge? gianlucaf Painting & Finish Work 27 11-14-2005 08:54 PM
