Better Screws For Hardibacker?
Old 04-25-2011, 10:15 PM   #1
Kingstud
Kingstud's Avatar
Trade: Handyman
Rewards Points: 75
I just finished prepping a room for tile, hardibacker to the ceiling on 3 walls.
The tile guy said use roofing nails because he didn't want screw heads sticking up. I told him I screw everything and it wouldnt be a problem. I figured my bosch impact would run em in good.
It didnt, in fact I watched the hardibacker lift off of the wall as I ran the screws in. Then the heads arent agressive enough to cut a good countersink.
Also the heads would strip out, I would run a screw in, strip it, back it out grab another. I did this for the 1st 100 screws.
So then I pre-drilled all the holes and then hit them with a titanium counter sink. Took forever, I worked 12 hrs on Easter Sunday
I looked at 3 different brand of screws, all the same chinese junk.
Does GRK or anyone make a good cement board screw?
The chair is against the wall, John has a long mustache.
Kingstud is offline
Old 04-25-2011, 10:24 PM   #2
Carpe Diem
angus242's Avatar
Trade: Smile 4 Tile
Rewards Points: 1,114
Re: Better Screws For Hardibacker?
I've never had issues with the Hardi screws you get from home cheapo. I also have CBU screw from Senco...no issues.
Angus
angus242 is offline
The Following 2 Users Say Thank You to angus242 For This Useful Post:
ApgarNJ (04-27-2011), Rio (04-27-2011)
Old 04-25-2011, 10:26 PM   #3
Dan_Watson's Avatar
Rewards Points: 2,460
Never an issue with the screws from the big ol orange store.
Dan_Watson is offline
Old 04-25-2011, 10:28 PM   #4
Geometrist
Warren's Avatar
Trade: framing/remodeling
Rewards Points: 6,207
Sounds like a collated screw gun would have paid for itself that day.
Warren is offline
Old 04-26-2011, 03:43 AM   #5
Particulate Filter
Metro M & L's Avatar
Trade: Flooring
Rewards Points: 1,266
dewalt impact and a new bit. I can even sink em with the 12v dewalt impact.
Metro M & L is offline
Old 04-26-2011, 06:29 AM   #6
Tech Geek
WarriorWithWood's Avatar
Trade: Remodeling Guru
Rewards Points: 1,342
IIRC (It's been a while) I've had that issue where the 1 1/4" wouldn't sink, they'd just strip the wood, so I went and grabbed the 1 5/8" screws. Problem solved.
-Dennis
WarriorWithWood is offline
Old 04-26-2011, 06:54 AM   #7
opiethetileman's Avatar
Trade: DIYer apparently
Rewards Points: 1,000
I use ring shanked 1 3/8 nails. Or shoot them in with my duofast coil siding nailer with 1 7/8 ss ring shankers. never had a problem.
Make sure if you are installing the hardi on the floor in thinseted and nailed or screwed.
opiethetileman is offline
Old 04-27-2011, 03:06 PM   #8
Kingstud
Kingstud's Avatar
Trade: Handyman
Rewards Points: 75
Since posting I figured something out. I realized the screws I have work great on wonderboard, never been an issue. This was my 1st time installing Hardibacker, apparently there are several brands of screws just for hardi backer (all green in clolor).
Our local supply sells hardibacker and wonderboard but not the screws for Hardibacker. I'll be talking to them about this today.....
Kingstud is offline
Old 04-27-2011, 03:23 PM   #9
Carpe Diem
angus242's Avatar
Trade: Smile 4 Tile
Hardie-screws seem to work on everything. Although I've used the gray Senco collated screws and have not had trouble with them. I rarely use Hardie.
Angus
angus242 is offline
Old 04-27-2011, 03:48 PM   #10
bmcquin's Avatar
Trade: deck builder
Rewards Points: 1,322
Angus, Why? I don't know what is a good backer board and what isn't so.......
bmcquin is offline
Old 04-27-2011, 05:20 PM   #11
Carpe Diem
angus242's Avatar
Trade: Smile 4 Tile
It's really personal choice. I just don't like Hardie in general. Maybe for floors but not walls. I'm not impressed with the new gen Durock's flex. I use Permabase when I need CBU. That's just me.
Angus
angus242 is offline
Old 04-27-2011, 06:21 PM   #12
It's Not a Toomaa!!
HandyHails's Avatar
Trade: Remodels
I don't like Hardi. Its too rigid for me. Not enough give. Permabase IS the best in my opinion. That being said, I usually use Durock anyway as it is easier to handle and bonds to thinset like no ones business. I've never had a problem getting any screws to sink in it either. Also its like $2 a sheet cheaper then Permabase or UltraBacker and they just lowered the price at B-Lowe's on the 5/16" sheets to the same price as the 1/2".
I generally use cheap galvanized 1 5/8" coarse thread screws on the walls in showers. If not Ditra, I'll use 5/16ths CBU on floors bedded in cheap thinset (floor adhesive by name at B-Lowes $5 a bag) and that will get 1 1/4" screws trying not to hit the joists.
PS. - Wonderboard Sucks. I never use that crap.
Josh
hhicontracting.com
HandyHails is offline
Old 04-27-2011, 06:30 PM   #13
bathroom guru
jarvis design's Avatar
Rewards Points: 560
I like permabase as well. Easy to cut and screw. I use 1 3/4 floor screws.
I also like the fact I can get 32x60 and 36x60
Bathrooms Built for Life.
www.ExpressBath.ca
519-495-4062
jarvis design is offline
Old 04-27-2011, 09:09 PM   #14
detroit687's Avatar
Trade: carpenter
i use a drywall screw gun run it in back it out and sink it. Backing it out to me seems like it makes sure the underlayment is tight to the subfloor. screwguns fast and you can bounce the clutch.
detroit687 is offline
Old 04-27-2011, 09:34 PM   #15
Dan_Watson's Avatar
Did you mud under the CBU?
Old 04-27-2011, 09:38 PM   #16
tileman2000's Avatar
Trade: tile contractor
Rewards Points: 528
The square head screws seem to solve the stripping problem, in my case anyway.
Michael
Miller Tile on Facebook
tileman2000 is offline
Old 04-28-2011, 10:31 PM   #17
Kingstud
Kingstud's Avatar
Trade: Handyman
Rewards Points: 75
This sucks, we don't get any of the products you guys named.
The local store has the hardi screws at the main store and are going to carry them in the local since I talked to the manager.
Should I request they stock a better CBU? which one?
AlwaysC- No the floor is slab, this is for wall tile.
Kingstud is offline
Vinyl Window Screws Wayfarer Doors Windows, Siding and Doors 12 11-23-2010 12:11 AM
Laminating screws secure? Ted White Drywall 10 05-17-2010 01:33 PM
GRK Torx-Head Screws - Anyone Else Like Em? BuildersII Tools & Equipment 25 02-20-2010 11:50 AM
Deck Screws vs Joist Nails subybohn Decks & Fencing 100 11-25-2009 03:52 PM
Slotted screws and other peeves! WNYcarpenter General Discussion 31 10-10-2009 12:30 PM
