Go Back   Contractor Talk - Professional Construction and Remodeling Forum > Trade Talk > Flooring
Old 01-01-2007, 10:16 PM   #1
ruskent's Avatar
Trade: Outdoor D/B
Best way to refinish hardwood floor?
Since this is my off season and there is no snow to plow, i figured it is a good time to do some work on my bed room. I have a 8x12 bed room with oak hardwood floors that are 30 years old. The floor has scratches just nothing deep. I just want to get it looking better and a different color stain.
What kind of sander do i want to rent for the sanding? What are the right steps to refinshing the floor? How many coats of poly do i want?
Any help you could give i'd appreciate.
Matt
ruskent is offline   Reply With Quote
Old 01-02-2007, 07:21 AM   #2
osborn's Avatar
Trade: Licensed Home Improvement Contractor
I used the random orbit with four pads last summer. It was too easy. Years ago I butchered my floor with a drum sander and had a company redo it.
osborn is offline   Reply With Quote
Old 01-02-2007, 03:23 PM   #3
Trade: Carpentry, Remodeling
If you get the scratches out with an orbital sander, go ahead and do it. You can't really ruin a floor with one of those things. That said, they do take a long time on hardwood. A long time.
If it looks like you need a drum sander, all I can say is don't. Hire a pro. Really. Honestly. Google "should I refinish my own floors?" You will find stories from otherwise sane and reputable tradespeople who have contemplated jumping off bridges after attempting to do it.
This guy has some good advice:
But, here's the good part! You can finish them yourself. Just get a pro to do the sanding. Finishing is the fun part anyhow. And even pros, (read above) will concede that many people can apply finish to the own floors better than the pros, if only because they're willing to spend the extra hours to make the floor look like glass
Chris G is offline   Reply With Quote
Old 01-02-2007, 03:43 PM   #4
C.C.R.'s Avatar
Trade: Remodeling contractor
I've been called in on many occasion to redo a H.O. refinish. Want it done before the wife gets home so you can take the credit add 15% When I started doing hardwood I was able to take the drum sander and go. With very little supervision from my boss. But it takes finesse and a good eye. DIY with good results has been done before, Just make sure you keep about $3.00/sqft put aside for the pros. That said, if you've never touched a drumsander before and your looking for good results over speed, go with the multi-disk orbit sander depending what the floor looks like I would start heavy (60 grt) and work up to 100grt + for staining don't forget edges and corners. Good luck
Complete Custom Remodeling
"When Quality is Top Priority"
www.completecustomremodeling.com
C.C.R. is offline   Reply With Quote
floor not level for hardwood laminate sterling stone Flooring 14 02-18-2007 05:41 PM
Hardwood floor repair Nutty Carpentry 5 01-05-2007 11:25 AM
Help with clear coating a hardwood floor pdiesel5 Flooring 5 11-03-2006 08:56 AM
Hardwood floor indented please help dkillianjr Flooring 37 09-22-2006 08:06 AM
Basement floor dilemma ron schenker Flooring 11 07-02-2006 08:36 PM
