Best Pressure Washer For Garage Floors ?
Old 09-12-2017, 10:16 AM   #1
helena2133's Avatar
Trade: PWR
Rewards Points: 4
We want to paint and clean our garage floor. Should we hire professionals or do it ourselves?
also, what is the best pressure washer for garage floors ?
We have seen the Pressure Pro E4040HC Gas pressure washer.
Is it best ?
helena2133 is offline
Old 09-12-2017, 10:28 AM   #2
Eater of sins.
ScipioAfricanus's Avatar
Trade: Designer/Drafter Extraordinaire
Rewards Points: 960
Re: Best Pressure Washer For Garage Floors ?
Is it best ?
You may want to ask this question over at the sister site DIY Chatroom.
HERE is a link.
Andy.
ScipioAfricanus is online now
Old 09-12-2017, 10:39 AM   #3
helena2133's Avatar
Trade: PWR
Rewards Points: 4
Thanks
Old 09-12-2017, 11:01 AM   #4
hdavis's Avatar
Rewards Points: 4,459
Hire a pro.
hdavis is online now
Old 10-18-2017, 09:10 AM   #5
macrosblaster's Avatar
Trade: No Idea
Rewards Points: 4
Wink
Any Medium Duty or a Heavy Duty pressure washer would do the job.
Get a Gas Pressure Washer which has a PSI between 2,900 and 3,200.
That would be perfect for your garage!
(PS : I've compiled a list of pressure washers that might be worth checking so you can clear your doubt)
macrosblaster is offline
Old 10-23-2017, 08:20 PM   #6
DiaperRiot's Avatar
Trade: Painting, Landscaping, & Fence Installation
Rewards Points: 148
If you're painting your garage floor, let it be known that hot tires can peel floor paint.
DiaperRiot is offline
Old 12-26-2017, 05:17 PM   #7
dprimc's Avatar
Rewards Points: 590
Pressure washing does not create the Concrete Surface Profile need for epoxy to adhere to concrete. You need a CSP3 which is obtained by shot blasting or grinding.
Of course, if you are going to apply a cheap floor paint from a box store, it will likely fail anyway, and inadequate prep will just speed up the process.
www.seattlesurfaces.com
218 Main St. Suite 173b Kirkland, Wa 98033 (425) 586-0706
Twitter @SeattleSurfaces
dprimc is offline
What pressure washer do you guys use for decks and fences? adkr3153 Decks & Fencing 72 02-03-2018 12:38 PM
Question about workin on my own oil burner InterCounty HVAC 6 04-29-2013 01:05 AM
Pressure washing and window seals. SuperiorHIP General Discussion 9 08-05-2012 08:19 PM
Pressure Washer Stolen advise new one.. SeasideCA Painting & Finish Work 5 07-22-2012 06:58 PM
pressure washer Traditions Painting & Finish Work 10 05-06-2007 11:54 AM
