platinumLLC
Guest
Posts: n/a
Best Blade For Cutting Laminate
What is the best 12" blade for cutting laminate? Seems like the blades I have tried wear out after doing one laminate job. Is there a blade that lasts longer when cutting laminate or one made specifically for laminate? I have looked into the laminate trimmers that are like a paper cutter but the are pretty expensive and I already have a miter saw so plan on just using that for now if I can find a blade that lasts unless there is a decent laminate trimmer for a reasonable price? Thanks
Floordude
Guest
Posts: n/a
Re: Best Blade For Cutting Laminate
I wouldn't waste a 12" blade on a laminate floor. It is bad enough wasting a 10" blade.
I go with Harbor Freight 10" blades @$20 a piece. |
silvertree
Guest
Posts: n/a
I use the 40 tooth cheapos at Menards 20 bucks
Mike Costello
Guest
Posts: n/a
I have a Magnum Laminate Shear, it seems like big bucks to buy but it is totally worth it if you do alot of lam jobs
Its dustless and I am on year three of the blade with tens of thousands of sq ft run through it |
#5 | |
PrecisionFloors
Guest
Posts: n/a
Re: Best Blade For Cutting LaminateQuote:
Platinum, if you are using a mitre saw to make cuts, thats where the problem lies. Use a table saw. You will see blade life increase 1000%...no kidding. A mitre saw is for trim and cutting dimensional lumber, not forcing a blade through melamine and aluminum oxide And I agree with Floordude as well....I only use cheap Irwin 7 1/4" blades on my table saw for laminate. Anything else is a waste of money. Last edited by PrecisionFloors; 05-03-2009 at 02:37 PM. |
platinumLLC
Guest
Posts: n/a
Thanks guys. I don't do a ton of laminate but probably average 1 job a month. I just looked at the magnum shears, is the L9 a decent one? I found it for around 425 so that's not a horrible price but still a decent investment. Is this shear good enough for your normal laminate install? What would be the advantage of the 13" or 20" magnum shear? I have never installed boards wider than about 7-8". Maybe my best option is to get the cheap blades and treat them like disposables.
#7 | |
PrecisionFloors
Guest
Posts: n/a
I would get the largest one you can fit in the truck and afford. I bought the 13 a few years ago and kinda wish I had gone to the 20, but I had very limited space at the time. The only downside to the larger ones is the weight, but I would probably build some kind of stand on wheels. I'm gettin too damned old to work hard...gotta work smart now
Mike Costello
Guest
Posts: n/a
Thats my only complaint. The damn thing is heavy!
I have the 20 inch. its great for engineered wood too and actually makes a pretty clean cut |
kaptin
Guest
Posts: n/a
i was wondering what is the install price for laminate wood in a commercial budiness in houston tx
Mike Costello
Guest
Posts: n/a
Twobitty fourbitty billiondy
PrecisionFloors
Guest
Posts: n/a
Re: Best Blade For Cutting Laminate |
platinumLLC
Guest
Posts: n/a
kapton-what is itchen and bathroom remodeling?
Price to install laminate floors in Texas-.39 a square foot Price to pay for a good spell check- Priceless |
DmitriyZ
Guest
Posts: n/a
I use a jig saw for end cuts. Blades are cheap. table saw for rips. Work well and less dust if you work inside the house.
| Best blade to cut Jatoba | Laketahoedan | Finish Carpentry | 2 | 10-15-2008 08:40 PM |
| What to charge to pull up 325sqf of Laminate flooring?? | TileMan77 | Flooring | 3 | 07-17-2008 08:57 PM |
| Best Utility Knife | Journeyman T | Tools & Equipment | 48 | 02-20-2008 08:54 PM |
| What Blade do you use for Laminate Flooring? | dayspring | Tools & Equipment | 8 | 01-21-2007 02:04 PM |
