Go Back   Contractor Talk - Professional Construction and Remodeling Forum > Trade Talk > Flooring
Old 03-31-2009, 06:31 PM   #1
Remodeling and Carpentry
jkcustmcarpntry's Avatar
Trade: Remodeling/Carpentry
Bathroom Tile Application
I have done tile a few different ways in the past. One way I have laid metal lathe and then poured concrete to set my tile on, also doing it that way for the tub walls. I have also used DuraRock on the floor, laying thin set first and then setting the DuraRock and waiting to the next day to set tile. I have also done this in the tub area.
I know that they have some new materials one has a drywall core i believe and install just like drywall and start tiling. Whats the best way to prep for the tile. I would like to know of new products, the layering process (studs,vabor barrier, drywall, and so on, just examples) and any suggestions and/or pictures and links would be great to.
Thanks, John
J Karalunas Custom Carpentry LLC
jkcustmcarpntry is offline   Reply With Quote
Old 03-31-2009, 07:11 PM   #2
jarvis design's Avatar
Check out Schluter Kerdi and Ditra
Do it Right the First Time....or someone else will!!
www.JarvisDesignBuild.ca
jarvis design is offline   Reply With Quote
Old 04-19-2009, 05:21 PM   #3
Tile Installer
Trade: Flooring
Awesome Product very easy to install, but a little pricey a cheaper alternative is hardibacker.
Javier559 is offline   Reply With Quote
Old 04-19-2009, 05:32 PM   #4
Sean
SLSTech's Avatar
Hardibacker is not waterproof, you still need a waterproofing membrane applied to it or plastic behind it (which of course gets punctured by nails or screws
SLSTech is offline   Reply With Quote
Old 04-19-2009, 09:59 PM   #5
Would you put green board (mudded,sanded and primed) behind the hardi board first?
Old 04-19-2009, 10:02 PM   #6
Cpt. Chaos
PrecisionFloors's Avatar
Trade: Hard Surface Flooring
No. Greenboard has no place in any modern bathroom.
Precision Flooring
Hampton, VA (757) 256-0848
Tile, Hardwood, Laminate, and Resilients
PrecisionFloors is offline   Reply With Quote
Old 04-19-2009, 10:30 PM   #7
what would you do then? Drywall then hardi on top or what then? I have a bullnose with a 1/2" +/- return so i have to build out that 1/2". drywall then durarock? Thanks for all the help everyone.
Old 04-20-2009, 07:26 AM   #8
demo master
kevjob's Avatar
use 1/2 inch plywood rips to fur out no green drywall behind hard.
kevjob is offline   Reply With Quote
Old 04-20-2009, 11:56 AM   #9
Cpt. Chaos
That's not bullnose, it's mudcap. Return it and spec bullnose.
What product is it?
edit: If you can't return it and you can't/don't want to pull mud, you could use 1/2" Durock over the drywall and Kerdi the whole thing.....That's a lot of work though. Hire somebody to mud it
Precision Flooring
Old 04-20-2009, 01:42 PM   #10
Trade: flooring
John,
you have alot of catching up to do in new tile products and specs. Since you're in Michigan get over to a store called The Tile Shop or their website. That will get you started. Then get over to Tile Council of North America website. Also, any backerboard has an installation guide either where it's sold or on their website. Of course the tile forum here or some others will keep you in the know and reading into the night. Good luck.
olzo
olzo55 is offline   Reply With Quote
Old 04-21-2009, 09:06 AM   #11
Thanks to all and yes im a little behind in the tile field. Things look like they have changed alot and easier to install. Thanks again.
Old 05-07-2009, 12:01 PM   #12
Trade: Tile,Marble & Granite
Old school
Take a look at my profile and see some pictures , old school tile methodes.
detroitMi is offline   Reply With Quote
Old 05-28-2009, 10:57 PM   #13
RLKMarble's Avatar
Trade: Custom Tile Marble
Send a message via AIM to RLKMarble
Hardibacker isnt waterproof...thats news
RLKMarble is offline   Reply With Quote
Old 05-29-2009, 08:37 PM   #14
Hardibacker will not rot when exposed to water, however, water can pass through it.
Old 05-29-2009, 10:29 PM   #15
WarnerConstInc.'s Avatar
Trade: Sure, what you got?
I like Denshield.
WarnerConstInc. is offline   Reply With Quote
Old 05-30-2009, 08:44 AM   #16
Internet Creep
angus242's Avatar
Trade: Kitchen/Bath Remodeling, Tile
For bathrooms, we use DensArmor and then Kerdi over any wet location.
"If you're good at something, never do it for free."
angus242 is offline   Reply With Quote
Tile over Tile fireguy Flooring 3 02-26-2009 11:36 PM
Putting Tile in My Bathroom SHAWNPAINTS Flooring 24 01-11-2009 01:52 AM
Bathroom tile question Footfall Ceramic & Stone Tile 7 06-24-2008 10:55 PM
Learning to install Floor and Wall Tile!! TurnkeyConst Flooring 25 01-17-2008 08:01 PM
Heres our latest bathroom with curved walls and tile TurnkeyConst Remodeling Picture Post 14 10-03-2007 11:20 AM
