Trade: Basement Renovations
Basement Subfloor
I have finished a couple basements this year. For the subfloor I have installed Platon (nippled membrane) over the concrete and then anchored down 3/4 in TG ply and OSB to complete the subfloor.
Platon suggests that his is an excellent waterproof and warm subfloor system. Just wanted to know if anybody else has gone this route and what their thoughts were. Thanks. Kevin |
#2 | |
Its all ball bearings
Trade: Tile
Re: Basement SubfloorQuote:
Angus L+M+O+P=C ![]() "Promise only what you can deliver. Then deliver more than you promise" |
Trade: Design/Build Remodeler
Have not used the product but "nippled membrane" has my attention.
"Being willing is not enough; we must do". Leonardo da Vinci Da Vinci on the web or Da Vinci On Facebook |
Flooring Installer
Trade: flooring
Anytime you put wood on concrete, it's a problem waiting to happen. And why would you put OSB over ply? That makes no sense at all.
Flooring installer since 1973 Armstrong certified |
Trade: interior remodeling
Please send pictures of the last couple of basements that you did.
I never used this product--How did you deal with stair height? floor drains? What about moisture entrapment? LOVE TO SEE PICTURES |
#6 | |
Their website BTW says dimpled. It's an innie, not an outie.
Knowledge Factory
How is it water proof, or moisture vapor proof, if you poked 32 holes per 4x8 sheet of plywood?
Illusion of Perfection
Does the vertical height even meet code after all those layers?
How tall are your customers?
There's an interesting article in FHB this month on this topic. Can't say I'm crazy about it yet but it was an interesting read. In that article it specifically addresses the point of not penetrating the vapor barrier and I would definitely heed that advice if I were to do try this.
One tile at a time
Trade: flooring installation
i always though it was total bad idea to install hardwood flooring in basements. i think there isn't any manufacturer even warranties the product. also why was your choice OSB over plywood you know they use chemicals with OSB board that always not agree with wood glue.
Trade: Home Building
What kind of OSB did you use? I've always used AdvanTech for my subflooring and I never had issues with wood glue.
I have always thought you couldnt glue anything to AdvanTech
One tile at a time
hey i checked in to that board yes it's fine but basement part is the problem, moisture and water runs of wall even now that is why, but for future you may want to read Bosticks BEST glue specs it explains on there what to do when installing sub floor over concrete floor
Where Plywood Substrate Over Concrete is Required: Using a 1/4" x 1/4" square-notched trowel to apply adhesive, set 4' x 4' sheets of 3/4" exterior grade plywood into wet adhesive. Score plywood sheets on the backside every 8" to 10" by using a circular saw and cutting one half the thickness of the sheets. Scoring or “kerfing” takes the tension out of plywood and helps prevent possible warping or curling. Allow to fully cure before nailing strip. this may be good idea for all boards because it makes scene. good luck floorswedo.com |
Trade: Remodel and new construction Austin, TX
I'm in Austin and the code is no more than 7 1/2". So you need to figure out the height of the finished floor and the finished treads.
Robin303 Army Air Slideshow |
Sam
Trade: Wood Cork and Leather Flooring and more
Advanced but similar system is called DriCore and been around about 10 years, I had done many basements floors on East Coast and Canada. Too bad now I am in a part of country not many basements exist
.Here is the link: http://www.dricore.com/en/contrac.aspx http://www.dricore.com/en/inspace.aspx Last edited by astor; 11-20-2009 at 09:29 PM. |
Trade: Flooring
I've used Dricore with good results too. A couple of years ago, we had over a foot of rain in a short period of time. We had done over a basement and put in a pedastal pump and a finished floor over dricore. I think hers was one of the few basements that stayed dry.
solid hardwood may not be appropriate below grade-what about a glue down engineered and prime the concrete if necessary?
#18 |
KemoSabe
This is foam backed with a decent R-value.
__________________________________ "Walking the fine line between production and perfection" __________________________________ |
| Tags |
basement subfloor ![]() |
| High moisture in subfloor | RJ Tile | Flooring | 8 | 06-19-2009 06:37 AM |
| Removing Porcelain Tile on Stapled and Glued Subfloor | ParaDiddle777 | Flooring | 20 | 11-08-2008 09:48 PM |
| New plywood subfloor over concrete slab | jeffaah | Construction | 5 | 10-17-2008 12:33 PM |
| Return Grill in the Basement | orson | HVAC | 7 | 10-03-2008 12:01 AM |
| HELP! Basement floor disaster | Profiter | Construction | 5 | 07-11-2006 09:01 PM |
