Bamboo On Stairs With Warped Stringers
Old 11-01-2008, 08:46 PM   #1
tgeliot's Avatar
Trade: Handyman / remodelling
OK so I've installed bamboo and tile throughout this condo, just have the stairs to finish. I did a single tread and the landing, and am ready to turn left and head on up the stairs. This is using special nosing pieces and regular flooring material, not whole bamboo treads. This is applied on top of the existing 3/4 sawn lumber treads.
On the one tread I've completed, I managed to fit the bamboo flooring nicely between the adjoining stringers with barely perceptible gapping at the end.
But holy cow these long stringers are a beast! They aren't parallel. The top/front edges are wider apart than the back/rear edges -- which means that every tread would have to be wider at the front than at the back, and even a bit wider at the top surface of the tread than the bottom. That much I'm ready for, with my home-built stair gauge. But wait, there's more! The stringers are not FLAT. That's right, they curve as they flare out, the angle between them growing larger towards the front of each tread.
Unless someone has a great suggestion here, I'm going to break down and buy some bamboo shoe molding to put over the inevitable gaps at the ends of the bamboo. The notion of trying to scribe the material to fit the stringers is just more work than I'm willing to invest.
Help!
tgeliot is offline
Old 11-01-2008, 09:05 PM   #2
I'm a Mac
Chris Johnson's Avatar
Trade: ICF Construction
Re: Bamboo On Stairs With Warped Stringers
Why? Why not do the job right? Shoe molding or 1/4 round is a great way to say I was lazy and wanted to cover up a mistake.
If it requires you to repair the existing treads and stringers first, do it.
What would you do if it was your house?
Chris
Chris Johnson is offline
Old 11-01-2008, 11:50 PM   #3
tgeliot's Avatar
This is a 43-year old condo, not a house. So rebuilding the stairwell as part of putting down a floor seems a bit much. What I would really love to do is figure out how to fit the bamboo boards against this curved surface, and I was hoping someone could suggest a clever method.
As to what I would do if it were my own home? I think I'd use the shoe molding.
tgeliot is offline
Old 11-01-2008, 11:58 PM   #4
Knowledge Factory
Floordude's Avatar
This is pretty basic stairs 101...
Take a scrap and cut it at the little angle until you get it right. now you know your angles. Measure and cut.
http://www.AustinFloorguy.com
Floordude is offline
Old 11-02-2008, 01:53 AM   #5
Mike Costello's Avatar
Trade: Flooring
Send a message via Yahoo to Mike Costello
I don't think I have ever run into a flight of stairs here in New England that are square.
Its not unusual and pretty standard stuff.
I use scribing paper and make a template of every stair. The could be serpentine shaped and you could tight fit them this way.
Mike Costello is offline
Old 11-02-2008, 09:03 AM   #6
Knowledge Factory
Floordude's Avatar
What I learned the hard way about a real tight fit is, if the stair structure itself is not stout, the tight fit to the stringer can squeak!!! Especially if they painted it recently. I had to use a razor blade and get it into the crack and shave it to reduce the squeaks, and a very picky client.
Old 11-02-2008, 12:35 PM   #7
"da Whale don't hesitate"
PrecisionFloors's Avatar
Trade: Hard Surface Flooring
Same here, if the Stair Wizard can't do it.
Lol. I think I have worked for that client a few time myself.
Another trick is to back cut the treads at about a 5 degree angle. It allows you to get them very tight and dropped in without binding up on the skirts.
Precision Flooring
(772) 237-9900
PrecisionFloors is offline
Tags
stairs, stringers, treads
What nailer to use for Bamboo Flooring aaks38 Flooring 24 10-25-2011 10:25 PM
How much to charge for new stairs skarrlette Finish Carpentry 40 12-14-2010 05:38 PM
Aussie stairs american style Hofmann Decks & Fencing 72 07-15-2010 06:15 AM
Are uncut stringers old fashioned for stairs? atari Finish Carpentry 2 05-30-2006 01:59 PM
