Originally Posted by Floordude
All concrete is suppose to be within that spec. When it is out, that is when we get to charge out the butt, to bring it within tolerance, so our floor can be to spec.
I hate to bust your bubble, but not ALL CONCRETE is supposed to within any specific specifications. It all depends on what the intended use of the slab will be for. Publix Supermarkets are considered "Super Flat" floors with a 1/8 inch tolerance within a 12 ft radius. Target Stores are at a tolerance of 1/2 inch per 12 ft. radius. While others are less stringent.
And Ff and Fl testing is not a "spec" it's a rule of measurement that dictates flatness and levelness of a slab. The "specs" are called out by the Arch/Eng firm responsible for the design process of the job.
However, poor concrete contractors need to be governed in some fashion and hence forth weeded out of the general populus of quality contractors that are out there performing and providing quality conscious products.
