Asbestos Tile
Old 06-21-2006, 10:01 AM   #1
dama's Avatar
Trade: woodworking
Asbestos Tile
A friend is looking to re-floor his house in hardwood, and came to me for advice (but I know a fair amount about cabinets not floors) and I need help. Any advice would be great, we have lots of questions.
He has Asbestos Tile flooring (we have not tested but it is a 1970 installation, 9x9 tiles, black mastic/glue) on his concrete slab 1st floor and upstairs on the plywood sub-floor.
Do we need to remove?
What are the best options for hardwoods? Floating hardwood? Do you see the seams like you do in cheaper versions of laminate?
Do you have any idea if you can nail through the upstairs tile? It seems pretty hard, and I am afraid it may crack and cause problems with stability or even sound "crunchy" when walking on wood over the cracked tile?
dama is offline
Old 07-03-2006, 12:49 AM   #2
Donedat's Avatar
Trade: Hardwood Flooring
Send a message via MSN to Donedat
Re: Asbestos Tile
I would have it tested. Not all tile of that era was made with asbestos. Even so, it is ok to scrape up the tile. It is the crumbly, powdery stuff that is dangerous. Don't cut it with a saw. Also, if it does have asbestos in it, land fills may have strict regulations in the disposal of it. You'll need to check with your local sanitation department on that one.
I admit...I don't know everything...but don't tell my kids I told you.
Donedat is offline
Old 07-04-2006, 08:31 PM   #3
Flooring Guru
Floorwizard's Avatar
Trade: Sales Manager
Re: Asbestos Tile
I do not ever recommend DIY removal unless you have it tested.
A floating floor will keep you from needing to worry about it at all.
Floorwizard is offline
Learning to install Floor and Wall Tile!! TurnkeyConst Flooring 25 01-17-2008 08:01 PM
Removing asbestos floor tile: Space suits needed? Ted W General Discussion 19 01-29-2007 02:38 PM
possible Asbestos Tile rservices Flooring 7 10-10-2006 10:21 PM
Got some design ideas for tile wainscoting? Mike Finley Ceramic & Stone Tile 2 05-09-2006 10:05 AM
