Anyone Use A Floor Blower To Dry Layex Poly?
Old 09-25-2007, 12:41 PM   #1
brianosaur's Avatar
Trade: hardwood flooring
Been using a lot of laytex poly on jobs recently. Since NY forced oil voc to change to 350 this summer, I just got sick of coats looking like crap.
Plus, I like the idea of knocking out small jobs with three coats in 1 day. However, when my guys are sitting around for 1 1/2 - 2 hrs with their feet up while the poly dries, I get a bit antsy.
We have been using fans, but they dont really seem to help all that much.
Does anyone use the larger commercial blowers like these one to speed up dry time?
brianosaur is offline
Old 09-25-2007, 05:31 PM   #2
Demonseed's Avatar
Trade: Commercial Flooring
Re: Anyone Use A Floor Blower To Dry Layex Poly?
I don't do hardwood, but we use those blowers on everything, drying adhesives, patch, primer, etc. The problem I could see you having, is these blowers move alot of air, which can result in alot of dust/dirt flying around. When we put the blowers on, with something like primer, you can also see that it does cause movement of it (the primer) during the drying process.
Demonseed is offline
Old 09-25-2007, 07:25 PM   #3
"da Whale don't hesitate"
PrecisionFloors's Avatar
Trade: Hard Surface Flooring
I will agree with Demon on this one. Another thing to think about is those types of blowers move a ton of air but it is in a pretty concentrated area....if you have ever used one for drying patch you know what I mean. You have to move the damn thing around 20 times to dry a 12X12 kitchen. I would think that may cause some finish issues.
Precision Flooring
(772) 237-9900
PrecisionFloors is offline
Old 09-25-2007, 07:45 PM   #4
I'm no finisher--don't even play one on tv--but I think the only thing that you can do to help is humidity and some air movement. Other than that, in your case I think you've just got to figure that time into the job and relax (maybe the guys are thinking about new and improved ways of making you more money in that down time). 2 hours is better than 24, and some things just take as long as they take. Last winter I put first coat of poly on about 200' of base, had it all spread out on temp racks in the garage, set the heater on low, and went out to pick up some hardware and towel bars, etc while it dried for 2nd coat. Partner comes along, decides to help and sets ole sally up to "core-temp-of-sun" setting. I come back garage is @ 120º and full of alligator textured base boards
neolitic is offline
Old 09-25-2007, 08:05 PM   #5
Knowledge Factory
Floordude's Avatar
Force drying poly is a recipe for a finish disaster. Adhesives & patching compounds, too.
As the top heals, it causes the finished product to be soft, also causing adhesion, concerns, and trapped bubbles. Also an inconsistent sheen and the possibility of poly beads at the gaps. And it a good way to have a lot of trash in your floor. With waterbased, you don't have to worry so much about cratering, or fisheyes
http://www.AustinFloorguy.com
Floordude is offline
Old 09-25-2007, 08:23 PM   #6
brianosaur's Avatar
Well I was only thinking about the 1st two coats. You do screen right? With the last one we'd be gone and let it dry normally. Fans do help. Even ceiling fans help. I never have had a problem with them. I was concerned about a blower with a large cfm causing ripples if its too close. Plus H20 applied with a pad is so darn thin it really doesnt have time to skin. It aint oil.
Old 09-25-2007, 10:22 PM   #7
Demonseed's Avatar
I agree with you on using an air mover on a finish coat for a hardwood floor, why i basically replied in that manner. I would like to Know why you think it is bad for adhesives and patch. If you think about it, drying/set/cure times for things are generally dependant on the actual conditions outside and inside the work area. Do you have the customer shut off all AC units and heat sources and open all of their windows? If it is a dry day and things set fast it is okay, but if not you just patch up the floor and go back the next day?
If you have to do 10-15k SF of VCT over (existing) cutback adhesive (that you have to flash) in the middle of July, and you don't use blowers, you must have some very slow workers, no deadline, and a generous customer.
Whats a good poly for tables rservices Specialty Coatings 6 06-10-2007 05:25 PM
Flat Poly to a satin poly lornmastro Painting & Finish Work 10 04-22-2007 07:00 PM
poly urethene donb1959 Painting & Finish Work 3 01-29-2007 11:37 PM
tinted poly Alkyd Painting & Finish Work 5 12-12-2006 10:00 PM
Oil base or water base poly? jhf469 Flooring 4 11-24-2006 11:36 PM
