Go Back   Contractor Talk - Professional Construction and Remodeling Forum > Trade Talk > Flooring
Old 01-17-2009, 12:00 PM   #1
J.T.
Aladdin Builders's Avatar
Trade: We are Florida State Certified General Contractors
Anyone have information on "Pearlite" combined with mortar?
I'm having a hard time believing that this product called "pearlite" is safe to use as an additive in thinset or mortar, does anyone have some information on this product or has anyone used this method??
They say it expands the mortar or thinset but to me this would weaken the bond and strength.
Aladdin Builders
South Florida
www.AladdinBuilders.com
www.surfacesbyAladdin.com
Aladdin Builders is online now   Reply With Quote
Old 01-17-2009, 12:06 PM   #2
Professiona Instigator
rbsremodeling's Avatar
Trade: Design Build Remodeling Contractor Washington, DC
What are you using it for as an additive in mortar for Plastering?
rbsremodeling is offline   Reply With Quote
Old 01-17-2009, 12:50 PM   #3
J.T.
The installers are using it for a rectified edge flooring tile project.....mixed with thinset??
Aladdin Builders
South Florida
Old 01-17-2009, 12:57 PM   #4
jarvis design's Avatar
The only reason I could see to add something like that would be to try to retain moisture or to make thinset into a medium bed mortar.
I don't think I would do it before talking to the manufacturer. Its quite possible adding that to the mix will void any warranty offered.
I have been using some self hydrating thinsets (Ardex XG3 plus), with no problems.
jarvis design is offline   Reply With Quote
Old 01-17-2009, 12:57 PM   #5
It was spec on a plastering job in the carribean for a few buildings. I have been back a few times and the plaster still looks good its about 6-7 years old.
Not sure about the use in thinset.
any idea why it is been used in the thinset? "why is it being spec?
I think in this application it was being used as a heat insulator, drywall was not popular or used much in this area??
It has been awhile and the conditions an use is vague to me now
Old 01-17-2009, 01:28 PM   #6
J.T.
This is not spec, but rather a brazillian installer trying to persuad the designer into a alternative low tight setting of the tile.
The reason is the doors are metal and they must keep the tile low to the floor. When you install a rectified butt joint tile you should use a mud bed otherwise you end up with trip hazzards everywhere, the installer wants to set it in thinset butt together....a disaster waiting to happen!!!
What do I know, I only been doing this crap since I was 12 years old.
Aladdin Builders
South Florida
Old 01-17-2009, 05:41 PM   #7
Tile Contractor
Pear-lite is sometimes used to make light weight concrete. It is also used in the nursery business to expand soil and retain moisture.
Here's my take on it.
Pear-lite will draw moisture from the thinset prematurely thereby causing the thinset to dry faster and thereby weaken the mix. This is opposite of what they want to happen. Pear-lite will also violate the integrity of the mass and further weaken the installation. They might as well use Styrofoam - same difference for expansion and it wouldn't draw the moisture prematurely.
(OK now that's a joke, I am not suggesting anyone use Styrofoam in their thinset.)
Bud Cline is offline   Reply With Quote
The Following User Says Thank You to Bud Cline For This Useful Post:
Aladdin Builders (01-18-2009)
Old 01-17-2009, 05:49 PM   #8
Pearlite thin set
Portland Cement
Pearlite
Hydrated Lime
Reinforcing Fibers
low shrinkage, soundproofing,fire insulation properties, light weight
The Following User Says Thank You to rbsremodeling For This Useful Post:
Need Pacific Region Information Muntzster General Discussion 3 11-11-2008 10:36 AM
Mortar Removal On Aluminum sxdirt Masonry 10 10-10-2008 07:03 AM
1st Row of Bricks on Lentil Dry, In Mortar, or Either? TomBrooklyn Masonry 16 08-30-2008 03:01 PM
Changing mortar color? kcrossley Masonry 1 12-17-2006 01:44 AM
tuckpointing 1890 home les digits Masonry 13 08-09-2005 03:56 PM
