Any Tips For Installing Prefinished Bamboo In My Own House?
Doing some bamboo in my own house next week, any tips from you flooring pros? I've never worked with bamboo before, I have about 700 sqft to install, going to use cleat nails rather than staples, any tips?
Thanks in advance, |
egotistical prick
Trade: Wood Inlay
Re: Any Tips For Installing Prefinished Bamboo In My Own House?
Not really enough info to go by. My best advice is to make sure you acclimate it first. I'll wait a bit before I trust a newer product. Especially anything coming from China.
Flooring Guru
Trade: Sales Manager
solid bamboo?
Engineered? Which brand? Strand Bamboo?
------------------------ "in 20 years you will regret more what you did not do than what you did" |
Prefinished 3 1/4" Bamboo, has been in the house for 3 1/2 weeks, boxes opened.
Trade: Squirrel Handler
Keep pandas out of there after you do it.
Some people climb mountains. I take out the trash. But we both do it for the same reason. |
| The Following User Says Thank You to mickeyco For This Useful Post: | Wolfgang (03-23-2009) |
Old school Ranger
Trade: flooring
Be sure to leave adequate expansion around all vertical surfaces. It is critical.
Does bamboo expand/contract more or less than typical hardwoods? I am just looking for pointers on the wood's characteristics, does it cut easily, does it splinter, etc,etc? What type of conventional hardwood is it most similar to?
Re: Any Tips For Installing Prefinished Bamboo In My Own House? |
#9 | |
Flooring Guru
Re: Any Tips For Installing Prefinished Bamboo In My Own House?Quote:
3 1/4 is good info...but still no help Bamboo....we know this... But my original questions will really help to figure this out... solid bamboo? Engineered? Which brand? Strand Bamboo?
#10 | |
, it is 5/8" thick solid bamboo , made in China, brand name NOVO.
Flooring Guru
You should use roofing felt to prevent squeaks.
Make sure you have something to add moisture to it after install.
I like Green things
No heels, or dragging stuff on it either.
Dave from Macatawa
Trade: GC, cabinet maker and remodeler
I just installed my first bamboo floor. Solid, 3" strand woven, all 6' lengths. Used the Bostich stapler with 2" staples (could not find the recommended 1.5") on 3/4" OCB,T&G sub, over a vented crawl space. Acclimated for two weeks. Separated all the boards. Used 30# felt underlayment.
Only difference with bamboo is density. First day was awful with the staples. Found that we had to back off the pressure to 65 - 75psi or the board was shattering and staples rolling over. Took several pieces and used them as sacrifices as we played with pressure until we found the aforementioned best results. Most of our other guns run at 110 - 125psi so this was a different experience. We got used to pulling about one in fifty staples even with the lower pressure but the staples that went in were great and we had no shattering. Used channel locks against the tongue or floor to pull the staples. One of my guys has arms like Popeye. Caution has to be taken on the beat board. The edges are fragile and if the beat board is not perfectly flat you will get some compression slivers and dents. Layout with all 6' was easy. Went from left to right, then back right to left. No butts closer than 24". Very little waste. Floor turned out great. Customer loved it. I was proud of it. Would use Bamboo in a heart beat because it is a good look and really tough. Good luck |
Dream Maker
Trade: residential construction
bamboo splinters are torture.
Knowledge Factory
Re: Any Tips For Installing Prefinished Bamboo In My Own House?Ya, tell me about it!! Just like needles. Bamboo shrinks and swells at twice the rate of red oak. It also shrinks and swells in 6 dimensions, unlike 4 dimensions for wood. Because of the grain, it will show every little scratch or dent.
#16 | |
Flooring Guru
We are assuming this is natural Bamboo and not strand..... If it's strand it is 200% harder than oak and shows very little....
Well its done now, I used my Bostitch MIII, 1 3/4" staples @ 110 psi, had very few problems with splitting. The only thing I had to do was to adjust the shoe with 2 layers of thin cardboard to make up for the 5/8" thick floor. I'm sure you can get a different shoe thickness to make up for it but who cares, cardboard is free.
Bamboo splinters are terrible, like tiny needles or glass splinters, just aweful! The only drawbacks (aside from the splinters) was the ease at which it splinters along the grain and how soft it felt when working with it. It feels much softer than a typical hardwood, but this probably depends on the age at harvest, I'm sure the older growth stuff is pretty hard. I got some pics of the stairs (no local supplier of bamboo nosings, didn't want to pay to mill 3/4" maple nosings down to 5/8", so I improvised using a maple nosing for laminate). ARRRGG, can someone tell me how to attach pics? I think it won't let me do it, maybe the files are too big (mine are 3.5 MB, it says limit is 200KB), how do you resize files? |
#18 | ||||
Flooring Guru
Plus there are different grades of Bamboo just like wood. Moso Bamboo tends to be the most durable. Quote:
#19 |
I'll try this again:
The first shot is before I finished off the tops of the stringers The next two are finished shots of the stairs before touching up the nail holes,etc |
#20 |
Flooring Guru
That is very good lookin!
Congrats!
| What nailer to use for Bamboo Flooring | aaks38 | Flooring | 24 | 10-25-2011 10:25 PM |
| house alarm in trailer | cooks | Low Voltage | 7 | 10-24-2008 09:59 AM |
| Brick House | Quinn | Decks & Fencing | 28 | 10-22-2008 11:04 AM |
| Pex vs Copper: Meter to house | stillwater | Plumbing | 51 | 09-17-2008 10:47 PM |
| Can this Real Estate is Take Off ? | oldfrt | General Discussion | 22 | 03-15-2008 04:18 PM |
