Any Input? Glued Down Flooring. - Flooring - Contractor Talk
Old 11-09-2017, 04:01 PM   #1
Dave in Pa's Avatar
Trade: restoration/remodeling
Rewards Points: 1,272
We have a job to do, remove approx. 100 sq.ft. of Mokawk ( I believe )3/8" t&g, 5" wide flooring. It is glued down to a concrete slab with the glue from hell! It has been wet for approx. 5 days now, and still will not release. The flooring is a mdf type material, with a thin layer or wood on top. We have tried all of our thoughts here!
Any input will be great-full! Thanks, dave
ps, the glue is softer, and tacky, but ever time you try to pry, force, lift, it just crumbles!!!
Dave in Pa is offline
Old 11-09-2017, 04:07 PM   #2
Mike-B's Avatar
Rewards Points: 662
Re: Any Input? Glued Down Flooring.
https://www.taylortools.com/taylor-tools-cjzg
Mike-B is offline
Old 11-09-2017, 08:03 PM   #3
Particulate Filter
Metro M & L's Avatar
Trade: Flooring
Rewards Points: 1,346
Cut it into 12" columns so you don't have to pry up long section. Get a burke bar.
Metro M & L is offline
Old 11-09-2017, 08:21 PM   #4
3bar's Avatar
Trade: carpenter
Rewards Points: 476
why is it wet?
rent a powered floor scrapper
+ YouTube Video
3bar is offline
Old 11-10-2017, 07:58 PM   #5
DiaperRiot's Avatar
Trade: Painting, Landscaping, & Fence Installation
Rewards Points: 148
Originally Posted by Mike-B View Post
Total overkill for 100 square feet.
Sounds like you should remove the floor however you can. And try and use a hand grinder to remove the glue. Throw some kitty litter on the glue, or else the hand grinder will just smear it instead of taking it off.
DiaperRiot is offline
Air waves under new vinyl flooring geospec Flooring 44 07-11-2012 05:50 AM
this is why your deck and flooring is so expensive roquevalente Flooring Picture Post 0 06-18-2012 07:37 AM
Removing engineered wood strip flooring that is glued down to OSB subfloor. UpNorth Flooring 5 04-09-2012 06:40 PM
flooring or cabinetry first coupe33 Flooring 68 10-06-2010 10:21 AM
laminate flooring placement nwksremodeler Flooring 7 06-19-2009 09:24 AM
