Go Back   Contractor Talk - Professional Construction and Remodeling Forum > Trade Talk > Flooring
Old 02-22-2005, 03:52 PM   #1
Trade:
Another question(floating install)
Looking to do a floating floor installation. The instructions say to lay the boards so that you have a gap of 1/16" for every 27" of flooring. My room length wise is 32ft. So that means I need a gap on both sides of 7/8". I was planning to use quarter round to conseal the expansion gap but I think that is just too large.
How do you handle this situation? I guess one option is T-molding somewhere in the flooring so that it has an extra expansion gap.
Any ideas?
Thanks
Codewiz is offline   Reply With Quote
Old 02-22-2005, 03:56 PM   #2
Flooring Guru
Floorwizard's Avatar
Trade: Sales Manager
1/4 Expansion usually up against any immovable object (walls ect...)
What you may be talking about is a break in the room if the room is really large, and yes, a t molding would do that.
Floorwizard is offline   Reply With Quote
Old 02-22-2005, 06:17 PM   #3
Teetorbilt's Avatar
You don't say where you are. Humidity RANGE is important, here we have a maximum of 40% (from 60-100, average is 80). Know where you are in this range when you install and set your gaps accordingly. Watch the drywall, here most drywallers hang about 1/2" off of the floor. With laminates and basic underlay you can go right to the wall and still have 1/2" (drywall thickness) to play with. I jump to a 3/8" gap at about 40+ ft. if the humidity is low and go to 1/8" if it is maxed.
Teetorbilt is offline   Reply With Quote
Old 02-22-2005, 09:15 PM   #4
Trade:
I live in Charleston, SC so the humidity is high. High pretty much year around. We don't want to move the baseboards up so I don't know how low the drywall is hung.
Old 02-22-2005, 09:30 PM   #5
Teetorbilt's Avatar
IMHO pulling the base makes for a more finished install and also gives a chance to upgrade the home with better bboard. Shoe mould looks like a tacky coverup, which it is.
Old 02-22-2005, 10:41 PM   #6
Trade:
I just don't see how it is possible without making the rest of the house look bad. The flooring is going down just in one major room. If I move the baseboard up in the one room, it will look stupid in the rest of the house. If I move all my baseboards up then it will mess up the carpet in the other rooms.
Old 02-23-2005, 01:23 PM   #7
Flooring Guru
I see plenty of times where the baseboards are moved up, or if it's just going to be slight, then the baseboards are ripped down so when it's installed, it matches height with the rest of the house.
Old 03-05-2005, 11:43 AM   #8
Trade:
T Moulding Whithin Door Threshol, Followed By 20 Mil Hemp Rope,around Expansion Gap.its Diferent& Cheap& Very Easy To Install
toddy is offline   Reply With Quote
small install job. does this sound right? AGC Finish Carpentry 9 05-12-2007 11:28 AM
Alright businessmen ... I'm gonna give it one more try ... breakin even dirt diggler Business 30 02-27-2007 12:34 PM
correct way to install Michaela521 Electrical 1 08-13-2006 04:36 PM
labor rate to install crown bellerose Carpentry 14 08-08-2006 05:23 PM
outdoor tile install southcoastbuild Flooring 3 01-09-2006 11:03 AM
