Almost Done With The Basment
Old 04-14-2006, 07:46 AM   #1
heavyparts's Avatar
Trade: dealer sales
Thinking of putting carpet in the basement using a thick pad but how do you install it on the concrete with tackless??
heavyparts is offline
Old 04-14-2006, 08:27 PM   #2
tile contractor
Bill_Vincent's Avatar
Trade: Ceramic and stone tile contractor
Send a message via ICQ to Bill_Vincent Send a message via MSN to Bill_Vincent
Re: Almost Done With The Basment
Not to put a kink in your plans, but before you put carpet in there, you might want to do a moisture test on the slab, first.
"Whether you think you can, or you think you can't, you're probably right."
http://www.creativeceramicandmarble.com
Bill_Vincent is offline
Old 04-14-2006, 08:38 PM   #3
Flooring Guru
Floorwizard's Avatar
Trade: Sales Manager
the pad should be glued down with a pad glue.
are you saying you are installing without tack strip?
Floorwizard is offline
Old 04-15-2006, 03:55 AM   #4
747's Avatar
You use a can of spray adhesive to keep pad down. The tack strips go around the perimeter and you use cement nails. Meaning they use a certain nail for plywood and a cement nail for cement. That is the way they did mine. They used a liberal amount of that spray adhesive on the floor for the pad.
747 is offline
Old 04-15-2006, 12:24 PM   #5
Tile Contractor
Bud Cline's Avatar
You can buy "tackless" with masonry nails already started in the strips the same as regular tackless with regular nails that would be intended for wood subfloors.
TO OUR VALUED CUSTOMERS:
Please manage your children.
Any children unattended throughout the day
will be given a Free Mountain Due at our regular quiting time.
Bud Cline is offline
Old 04-17-2006, 07:31 PM   #6
adams,b's Avatar
Trade: hardwood floors
has any one seen the glue you can use for tack strip that alows you to stretch in like 2 hours. That some bad stuff.
adams,b is offline
Old 04-18-2006, 06:14 AM   #7
Mike Costello's Avatar
Trade: Flooring
Send a message via Yahoo to Mike Costello
Back when I was still laying rug...stopped a year ago, I used it all the time. It was a modified urethane adhesive that was activated with a spritz of water. Did what it said too, you could power stretch off it in two hours.
Mike Costello is offline
Old 04-19-2006, 07:16 PM   #8
adams,b's Avatar
thats top notch!
adams,b is offline
Worst Lead Of The Month go dart General Discussion 32 07-23-2006 03:28 PM
